Something happened on an upgrade. I am not sure what. The result on further upgrades is listed below. I tried the apt --fix-broken install with no success. I listed that output afterwards.
$ sudo apt upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libglvnd-dev : Depends: libglvnd0 (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
Depends: libglvnd-core-dev (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
Depends: libegl1 (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
Depends: libgles2 (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
Depends: libgl1 (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
Depends: libglx0 (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
Depends: libopengl0 (= 1.0.0-2ubuntu2.1) but 1.0.0-2ubuntu2.2 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
$ apt --fix-broken install
Do you want to continue? [Y/n]
(Reading database ... 469780 files and directories currently installed.)
Preparing to unpack .../libgles1_1.0.0-2ubuntu2.2_amd64.deb ...
Unpacking libgles1:amd64 (1.0.0-2ubuntu2.2) ...
dpkg: error processing archive /var/cache/apt/archives/libgles1_1.0.0-2ubuntu2.2_amd64.deb (--unpack):
trying to overwrite '/usr/lib/x86_64-linux-gnu/libGLESv1_CM.so.1', which is also in package nvidia-340 340.106-0ubuntu3
Preparing to unpack .../libglvnd-dev_1.0.0-2ubuntu2.2_amd64.deb ...
Unpacking libglvnd-dev:amd64 (1.0.0-2ubuntu2.2) over (1.0.0-2ubuntu2.1) ...
dpkg: error processing archive /var/cache/apt/archives/libglvnd-dev_1.0.0-2ubuntu2.2_amd64.deb (--unpack):
trying to overwrite '/usr/lib/x86_64-linux-gnu/libGLESv1_CM.so', which is also in package nvidia-340 340.106-0ubuntu3
