44
I need to rename a bunch of files in order to fix their sort order, therefore I need to be able to do a sort of "find and replace" so I can replace chunks of the filenames at a time.
What tools should I use? I prefer GUI but a command line tool recommendation would also be fine.
pomsky
  • 70,557
Jorge Castro
  • 73,717
16 Answers16
54
There are a few but I recommend gprename Install gprename which is a good compromise between usability and functionality.
Other tools are: rename, krename Install krename , pyrenamer Install pyrenamer , cuteRenamer, ...
muru
  • 207,228
Ralf Hersel
  • 2,793
10
I really like qmv from the renameutils package. It enables you to use your favorite (terminal based) text editor to rename files. I prefer to invoke it with -f do which gives you a single column (one row per file) with filenames. Combined with the power of Vim it gives you all the tools you need to do massive filename editing.
http://www.nongnu.org/renameutils/
dempa
  • 309
Métamorphose
https://github.com/metamorphose
may be a little difficult to handle, but really powerful!
daniels
  • 275
perseo22
  • 1,056
If you like the shell and perl regular expressions I'd recommend rename. It's as plain as it's name.
con-f-use
  • 19,041
thunar file manager is a GUI with a bulk rename option
http://thunar.xfce.org/pwiki/documentation/bulk_renamer
it's not standard on Gnome but can be installed through the software centre
Simon B
  • 1,296
If you are familiar with Emacs, I think nothing beats Dired for this task. Even if you don't use Emacs that often you may find Dired a handy tool.
sudo aptitude install emacs23-nox
Start Emacs Dired mode for a directory:
emacs -nw path/to/dir/
Now enter edit directory mode:
C-x C-q (that is Ctrl+x followed by Ctrl+q)
You can now edit the filenames like editing text in every plain text editor. You may even chose to replace the filenames using regular expressions (note that unfortunately Emacs uses a different syntax than PCRE).
For example, to rename files with counter (starting by 1):
M-x replace-regexp (that is Alt+x followed by the string "replace-regexp" typed in the minibuffer at the bottom of the screen).
Replace regexp: DSCN\([0-9]+\).JPG
Replace with: \,(format "P%04d.jpg" (1 + \#))
To reuse a counter in the filename:
M-x replace-regexp
Replace with: \,(format "P%04d.jpg" (string-to-number \1))
When finished, type:
C-c C-c (that is Ctrl+c followed by Ctrl+c)
Or alternatively press the following sequence to abort your changes:
C-c Esc (that is Ctrl+c followed by Esc)
I tend to use mmv, which is command-line based, and has a somewhat quirky expression syntax but tend to solve most of my problems.
Eliran Malka
  • 1,245
  • 18
  • 36
Mr Shark
  • 137
find -execdir rename
This renames files and directories with a regular expression affecting only basenames, for example:
PATH=/usr/bin find . -depth -execdir rename "s/^find/replace/" '{}' \;
or to affect files only:
PATH=/usr/bin find . -type f -execdir rename "s/^find/replace/" '{}' \;
I have explained it in more detail at: https://stackoverflow.com/questions/16541582/find-multiple-files-and-rename-them-in-linux/54163971#54163971
If you use Nautilus and know how Nautilus Scripts work, you could use nautilus-renamer.
A newer GUI batch rename utility that runs on Linux (it also works on Mac and Windows) is Inviska Rename.
Besides the usual rename functions like replacing a portion of the text with some other text, inserting or removing text, renaming file extensions, and so on, this tool can rename folders, rename music based on tags, and rename photos using their Exif information. It can even batch rename using file attributes like the creation or modification date.
Other features include previewing the new filenames and undoing the batch rename, which I find very useful.
Source
Logix
  • 2,340
On the command line theres also the possibility to use magic of sed and shell:
ls *.c | sed "s#\(.*\)\.c#mv \0 \1.cpp#" | sh
Mr Shark
  • 137
For me the pyRenamer worked the best. Nothing (sadly) comes close to Total Commanders built it renaming tool. pyRenamer doesn't integrate with Krusader but considering the fact, that you don't use the renaming tools that often anyway, pyRenamer is a very good option.
This is the tool I use: rnm (man page) (more examples)
Some Usage:
rnm file-name -ns new-filename             # single file
rnm ./* -ns '/n//i/'                       # files will be sorted and indexed.
rnm ./* -rs '/search/new/g'                # 'search' in filenames will be replaced with 'new'
rnm ./* -ns '/fn//i/' -ss 'search'         # only files/directories which contain 'search' in their name will be indexed (renamed).
rnm ./* -ns '/fn//id/' -fo                 # file only mode, directories will be ignored.
rnm ./* -ns '/fn//id/' -fo -dp -1          # recursive to subdirectories all the way.
etc...
Jahid
  • 347
Personally I use Ant Renamer with Wine because nothing I've tried (Métamorphose, PyRenamer, GPRename, KRename) is as powerful, easy to install and easy to use. And it's still FOSS so I don't see the problem.
Krename is a KDE GUI for renaming files, generally found in most package managers.
This answer applies to removing leading numbers that may be found in music files such as mp3s. But Krename does mass rename as well.
  1. Load selected files or folder. Krename loads all files in the selected folder, just click on Open without having to individually select all files.
  2. Go to the Destination tab to overwrite or copy files to another folder.
  3. Go to the Filename tab, then to the Advanced Filename tab.
     "Advanced Filename" image showing the default settings.
  4. Start by removing the token $ in the Template window. A change takes place in the Renamed window below. No filenames appear, only the file extensions.
    3. Image shows that the filenames have been removed, leaving the file extensions.
  5. Click on Insert Part of Filename... and select the parts of the filename you want to keep. This operation will include all the files and the changes will be obvious in the Renamed window below.
    4. "Insert Part of Filename..." image showing how to select the filename by highlighting the preferred sections.
  6. Click OK. The files are renamed without the leading numbers.
    5. Final results showing.
  7. Finally, click Finished at the bottom right corner.
derHugo
  • 3,376
  • 34
  • 52
Scott
The cross-platform file manager Double Commander (released under GNU GPL 2 license) includes a fairly powerful "Multi Rename Tool":
doublcmd-multi-rename tool
I used to use the very powerful Bulk Rename Utility for Windows under WINE, but the Double Commander tool gets me most of the way there.
Dɑvïd
  • 2,186
