I wrote a small bash script to do the job.
#!/bin/bash
# Variables
extension='mobi'
report='report.log'
if [ -f $report ];
then
rm -rf $report
fi
echo $'renaming files . . .\n'
for filename in *.$extension
do
temp=$(echo $filename | tr '_' ' ' | tr '%20' ' ' | tr '[]' '()' | tr -s ' ' | sed 's/\.[^.]*$//' )
part1=$(echo $temp | cut -f1 -d-)
part2=$(echo $temp | cut -f2 -d-)
new_filename=$(echo "${part2#?} - ${part1%?}.$extension")
echo $(mv -v "$filename" "$new_filename") | tee -a $report
if [ $? -ne 0 ]; then
echo $'\n\nScript FAILED'
exit 1
fi
done
echo $'\n\nScript SUCCESSFUL'
exit 0
Create a .bsh file inside the directory in which your .mobi files are stored and paste the above code :
Open a Terminal with Ctrl + Alt + T and navigate to the directory in which your script is stored :
cd /path/to/directory/
To change the permissions of the script :
chmod +x <filename>.bsh
To execute the script :
bash <filename>.bsh
If for some reason the mv fails you will receive an error 'Script FAILED', otherwise you'll get 'Script SUCCESSFUL'.
Explanation
tr '_' ' ' replace underscores with whitespace
tr '%20' ' ' replace %20 with whitespace
tr '[]' '()' replace square brackets with parentheses
tr -s ' ' replace multiple spaces with one
sed 's/\.[^.]*$//' extracts only the name of the file without the extension
${string#?} remove first character of a string
${string%?} remove last character of a string
mv -v this will show in the terminal which files are being moved. -v stands for verbose.
tee -a changelog.log By default tee command reads from standard input, and writes to standard output and files. -a stands for append.
if [ $? -ne 0 ] checks if the previous command was successful.
report.log stores the previous and latest name of each file.
Note
The script assumes that the filename contains only one dash -
