There is an excellent answer to How do I add 1+1 using a quantum computer? that shows constructions of the half and full adders. In the answer, there is a source for the QRCA. I have also looked at this presentation.
I am still left with these questions:
  1. What does a truth table for a QRCA look like?
  2. What would a unitary matrix for a QRCA be?
  3. What would a circuit diagram for a QRCA look like? (There is an example of a 6-bit circuit in the arXiv paper)
user820789
  • 3,440
  • 13
  • 43
You don't want to know. It will be a gigantic complicated table that provides no insight whatsoever. At the very least you need to use boolean algebra instead of a table, but even that will be cumbersome and will require many intermediate values that ultimately are just a less-visual way of describing an addition circuit.
If it helps, here is the set of equations for a simpler operation, an increment operation. The equations define how each output bit can be computed from the input bits:
$o_0 = i_0 \oplus 1$
$o_1 = i_1 \oplus i_0$
$o_2 = i_2 \oplus (i_0 \land i_1)$
$\vdots$
$o_n = i_n \oplus {\Large{\land}}_{k=0}^{n-1} i_k$
It's a permutation matrix.
As a starting point, here is the permutation matrix corresponding to a 2-bit increment:
$$\text{Inc}_2 = \begin{bmatrix} &&&1\\ 1&&&\\ &1&&\\ &&1&\\ \end{bmatrix}$$
and a 3-bit increment:
$$\text{Inc}_3 = \begin{bmatrix} &&&&&&&1\\ 1&&&&&&&\\ &1&&&&&&\\ &&1&&&&&\\ &&&1&&&&\\ &&&&1&&&\\ &&&&&1&&\\ &&&&&&1&\\ \end{bmatrix}$$
I suspect you see the pattern. Just start with an identity matrix and shift it down by 1 (with the bottom row wrapping around to the top). To add 2, instead of adding 1 (i.e. incrementing) you would just shift down by 2 instead of by 1.
In an addition circuit, the amount of shifting depends on the other input. So you end up with a series of sub-matrices with increasingly-shifted diagonals:
$$\text{Add}_2 = \begin{bmatrix} \begin{bmatrix} 1&&&\\ &1&&\\ &&1&\\ &&&1\\ \end{bmatrix} \\& \begin{bmatrix} &&&1\\ 1&&&\\ &1&&\\ &&1&\\ \end{bmatrix} \\&& \begin{bmatrix} &&1&\\ &&&1\\ 1&&&\\ &1&&\\ \end{bmatrix} \\&&& \begin{bmatrix} &1&&\\ &&1&\\ &&&1\\ 1&&&\\ \end{bmatrix} \end{bmatrix}$$
There are many possible constructions. Here is one that works entirely inline:
addition circuit
You can play with this construction in Quirk.
Craig Gidney
  • 44,299
  • 41
  • 116
