14
In radio communication each accelerated electron in the transmitter antenna interacts with an electron in the receiver antenna by exchanging a photon.
Is that photon always a virtual photon as described in the diagram below rather than a "real" photon?
As I understand it, Feynman's definition of a virtual photon in his book QED is any exchanged photon that does not appear in the initial or final conditions. Therefore by his definition radio works by using virtual photons.
This is a perceptive question. Consider the following from the Wikipedia article "Virtual Particle":
As a consequence of quantum mechanical uncertainty, any object or process that exists for a limited time or in a limited volume cannot have a precisely defined energy or momentum. This is the reason that virtual particles — which exist only temporarily as they are exchanged between ordinary particles — do not necessarily obey the mass-shell relation. However, the longer a virtual particle exists, the more closely it adheres to the mass-shell relation. A "virtual" particle that exists for an arbitrarily long time is simply an ordinary particle.
However, all particles have a finite lifetime, as they are created and eventually destroyed by some processes. As such, there is no absolute distinction between "real" and "virtual" particles. In practice, the lifetime of "ordinary" particles is far longer than the lifetime of the virtual particles that contribute to processes in particle physics, and as such the distinction is useful to make.
Also, consider this from the Wikipedia article "Near and far field":
In the quantum view of electromagnetic interactions, far-field effects are manifestations of real photons, whereas near-field effects are due to a mixture of real and virtual photons. Virtual photons composing near-field fluctuations and signals, have effects that are of far shorter range than those of real photons.
The question here really is: "When are photons not virtual?". As explained in this article:
A virtual particle is one that has borrowed energy from the vacuum, briefly shimmering into existence literally from nothing. Virtual particles must pay back the borrowed energy quickly, popping out of existence on a time scale set by Werner Heisenberg's uncertainty principle.
So to answer your question- a photon exchanged over long ranges is outside of the scale of the uncertainty principle so the photon exchanged between the two electrons is real. Also see: http://en.wikipedia.org/wiki/Virtual_particle#Actual_and_virtual_particles_compared
kd88
  • 1,937
Radio and the like are best described quantum mechanically in terms of coherent states of the electromagnetic field. These states don't have a definite "number of photons", but are rather like an infinite mush of harmonic oscillator states that behave the most like classical electromagnetism.
lionelbrits
  • 9,543
