I'm confused about the units of wave functions in reciprocal space and their Fourier transform in real space. On one hand, I believe the Fourier transform of a reciprocal space wave function in 2D is given by
$$ (1) \ \psi(\vec{r}) = \frac{A}{(2 \pi)^2} \int d^2k \ \psi(\vec{k}) e^{i\vec{k}\cdot \vec{r}},$$
$A$ being the area of the system. According to this, the wave functions in real and reciprocal space have the same units, since the $m^2$ from the area cancels with the $\frac{1}{m^2}$ from the reciprocal space integration. On the other hand, according to Parseval's theorem,
$$ (2) \int d^2 r |\psi(\vec{r})|^2 = \frac{A}{(2 \pi)^2} \int d^2k \|\psi(\vec{k})|^2$$
(= 1 for normalised wave functions). For the LHS of (2) to be unitless, the units of $\psi(r)$ must be $\frac{1}{m}$. But if the units of $\psi(k)$ are also $\frac{1}{m}$, as the definition of the Fourier transform (1) implies, the unit of the RHS of 2 would be $\frac{1}{m^2}$, not unitless as it should be.
The context is excitons in a 2D material. The $\vec{r}$ is the relative coordinate of the electron and hole in real space, $\vec{r} = \vec{r}_e - \vec{r}_h $ and $\vec{k}$ is the relative coordinate in reciprocal space: $ \vec{k} = \frac{m_e}{M} \vec{k}_h + \frac{m_h}{M} \vec{k}_e$ (all 2D vectors, $m_e$ and $m_h$ the effective masses of the electron and hole, $M = m_e + m_h$). I learnt that a sum over k turns into an integral in the thermodynamic limit and gets a factor $\frac{V}{(2 \pi)^d}$, see equation (12) in https://cpb-us-w2.wpmucdn.com/u.osu.edu/dist/3/67057/files/2018/09/density_of_states-vjqh7n.pdf
