Separating hot and cold
Picture is from here
I think I have serious misunderstanding of the topic, and hope that somebody could point out where the mistakes in my reasoning are. Having looked through many other related posts, I still could not resolve the confusion. My thinking is the following:
Let's say the demon is trying to separate out the hot and cold particles into two groups, putting the hot particles to the left and cold ones to the right. What is preventing the demon to just have two bits of memory and still able to separate the particles? Let's say it sees a first particle (call it particle 1) approaching the gate. The demon needs to decide whether let it pass the gate (call it action 1). Hence it gives two labels of the particle: {hot/cold} and {left/right}. The demon stores these two labels into the two bits, and decide whether to let is pass (for example, if it turns out to be a cold particle approaching from the left, the demon will let it pass the gate). As it does so, the entropy of the gas decreases (because it becomes less uncertain), and the entropy of the memory of the demon also decreases (because it turns two uncertain bits into two certain bits). Next the demon does action 1 accordingly. Then the demon "erase" the memory, turning the two certain bits into two uncertain bits (or just leave the two bits there, recognising that the labels in them no longer represent anything), thus increases the entropy of the memory (would this increase in entropy cancel out the decrease in entropy of the memory of the previous action?), wait for the next particle (call it particle 2), and then overwrite the labels in that bits with the labels of particle 2. Then it act accordingly (call it action 2).
If the increase and decrease of entropy of the memory associated with action 1 and action 2 exactly cancel out, then does that mean the entropy of the whole system (gas plus demon) decreases?
There is a separate question (which has nothing to do with any claims or questions I made above), which is: Is it theoretically possible for a demon to have $N_{A}$ bits of storage (or any other storage that is sufficient to store all the relevant information in a macroscopic system) in its memory? If the demon has that, what will happen?
I would also appreciate explanatory reading recommendations on the entropy change of storing information, and on Landauer erasure.
pmpmpmpi
  • 141
You suggest the using two bits to store the state of the particles approaching the gate instead of $n$ bits for all of the particles. One problem is this presumes you know a particle is approaching the gate and that information has to be stored somewhere and if you're keeping that record for all $n$ particles then you have $n$ bits of data.
Leaving that problem aside, there is another issue. You write:
If you want to store more information in that bit it has to be put in a blank state otherwise you can't know whether it has changed. And you can't put a bit in a blank state without offloading the data somewhere because the equations of motion for systems are reversible.
For a review of some of the literature on Maxwell's demon explaining these issues in more detail see
https://arxiv.org/abs/2503.07740
https://arxiv.org/abs/1806.03532
alanf
  • 11,359
  • 16
  • 33
The arguments against sustained operation of Maxwell's daemon that are based on Landauer's erasure principle, and even arguments for Landauer's erasure principle itself, while very thought-provoking and interesting to think about, are still problematic; the known justifications are based on hypotheses/assumptions that may hold in special cases, but have no general justification. Consequently we don't know if Landauer's principle holds in general and also we don't know if Maxwell's demon can or cannot exist.
See e.g. the question and my answer here: Is it necessary to assume that equivalent microstates cannot get transformed into inequivalent microstates to derive the Landauer principle?
For a critique of the whole "business", see e.g.
John Norton: Waiting for Landauer, 2011
https://d-scholarship.pitt.edu/12539/1/JDN2011_1.pdf
John Norton: When a Good Theory meets a Bad Idealization: The Failure of the Thermodynamics of Computation, 2013
https://sites.pitt.edu/~jdnorton/Goodies/Idealization/index.html
