It has been noted here$\! { \, }^{\text(1, 2)}$, for instance, that
$$\mathbf{F} = \frac{d}{dt}\!\!\biggl[ \, \mathbf{p} \, \biggr]$$
is true in all contexts.
Likewise, in notable contexts it is apparently true that
$$\mathbf{F} = - \nabla \Phi := - \frac{d}{d\mathbf{r}}\!\!\biggl[ \, \Phi \, \biggr].$$
Is this, in a nutshell, a sufficient and valid justification for setting (in the corresponding suitable contexts)
the momentum operator as$\! { \, }^{\text(3)}$
$$\mathbf{\hat p } \propto -i \nabla := -i\frac{d}{d\mathbf{r}}$$
and setting the (potential) energy operator as$\! { \, }^{\text(4)}$
$$\hat \Phi \propto i\frac{d}{dt}$$
and both with the same constant of proportionality, $\hbar$, whereby
$$\mathbf{\hat F} = \frac{d}{dt}\biggl[-i\hbar\frac{d}{d\mathbf{r}}\biggr] = -\frac{d}{d\mathbf{r}} \biggl[i\hbar\frac{d}{dt}\biggr] \sim \frac{d^2}{dt \, d\mathbf{r}} = \frac{d^2}{d\mathbf{r} \, dt}$$
EDIT (related merely to formalities):
(${ \, }^{\text 1}$: Please note that the assertion to be noted here had been expressed explicitly in the form
$F = \frac{\mathrm{d} \mathbf{p}}{\mathrm{d} t}$ is true in all contexts.
However, since it appears admissible to take note of an assertion without strictly quoting and clinging to its original literal expression (as had been tacitly presumed already in the initial statement of my question, and as it seems to be thus confirmed) I'd like, as far as unambiguously possible, to express the operation of "differentiation" consistently by using (a form of) Leibniz's notation.)
(${ \, }^{\text 2}$: Please note that the question whose notable answer to which reference has been made above had been tagged (primarily) as has "https://physics.stackexchange.com/questions/tagged/newtonian-mechanics".)
($ { \, }^{\text 3}$: Please note that the indicated expression of the momentum operator is explicitly stated there as
${\bf \hat p } = -i \hbar \nabla$
and
In one spatial dimension this becomes: $\hat{p}=\hat{p}_x=-i\hbar{\partial \over \partial x}$,
where the nabla symbol ($\nabla$) is related to http://en.wikipedia.org/wiki/Directional_derivative#Notation .)
(${ \, }^{\text 4}$: Please note that the indicated expression of the energy operator is explicitly stated there as
$\hat{E} = i\hbar\frac{\partial }{\partial t}$.
user12262
  • 4,360
Note that forces are usually not well defined in a quantum mechanical context. Most forces (i.e. conservative, non-uniform force fields) are just ways of expressing position-dependent changes in momentum. For this to be a meaningful concept, we need position and momentum to be simultaneously well defined; and in quantum mechanics, they are not.
If you put together $\mathbf{F} = \mathbf{\dot{p}}$ and $\mathbf{F} = -\nabla\Phi(\mathbf{x})$, you get the expression $\mathbf{\dot{p}} = -\nabla\Phi(\mathbf{x})$. The left-hand side of this equation describes momentum, while the right-hand side is a function of position. But Heisenbergs uncertainty principle $\Delta p_i \Delta x_i \geq \hbar/2$ implies that position and momentum cannot be simultaneously well-defined, consequently the two sides of the equation are not simultaneously well-defined. This implies that this equation is invalid in quantum mechanics. (The connection to classical mechanics is basically that if you take the expectation value of both sides of the equation, it also holds in quantum mechanics. Google Ehrenfests theorem for more information about this.)
As for justifying the expressions for energy and momentum operators, perhaps my answer here is somewhat relevant?
jabirali
  • 1,850
