I have started learning quantum mechanics . I can now represent position eigenvector in momentum space(that is in the form of sum of momentum eigenvectors) and vice versa (fourier transforms of each other ). I can can represent energy eigenvector in position space(solving the time independent schrodinger equation) but stuck in doing the vice versa . I have tried but reached nowhere . Can someone explain me how can I solve the problem?
At your level, you might think of the eigenfunctions of your time-independent hermitean hamiltonian analogously to the exponential kernels of the Fourier transform, $$ |p\rangle= \int\!\!dx~{e^{ixp/\hbar}\over\sqrt{2\pi\hbar}} |x\rangle, $$ ($=e^{ip\hat x/\hbar} |p\!=\!0\rangle$.)
That is, if your orthonormal energy eigenfunctions are complete, $$ \sum_n \psi_n(x) \psi_n^*(y) = \delta(x-y)~~~~\leftrightarrow ~~~~\sum_n |\psi_n\rangle \langle \psi_n|= \mathbb{I}, $$ you may transform from one space to the other, assuming a swamp of fussbudget qualifications, of which this site is full.
To wit, $$ |\psi_n\rangle = \int\!\!dx ~ ~\psi_n(x) |x\rangle ~~~~\leftrightarrow ~~~~|x\rangle= \sum_n \psi_n^*(x)|\psi_n\rangle , $$ the latter of which might have an elegant summation or not, as in the textbook case of the SHO.
In any case, the complete orthonormal set of eigenfunctions of the hamiltonian are some type of transform you might analogize to the Fourier one. If it made you feel better, you might label the eigenvectors by $|E_n\rangle$ instead of $|\psi_n\rangle$.
- 67,623
