Let the time-dependent Hamiltonian be \begin{equation} H(t) = H_0(t) + \lambda H_1(t), \end{equation} where $\lambda$ is a small parameter. In the interaction picture (i.e. rotating frame w.r.t unitary generated by $H_0(t)$), the unitary operation obeys the following Schrodinger equation: \begin{equation} i\dot{U_I}(t) = \lambda H_I(t) U_I(t), \quad H_I(t) = U_0^\dagger(t) H_1(t) U_0(t), \quad U_0(t) = \mathcal{T}e^{-i\int_0^t H_0(t') dt'}. \end{equation} My objective is to solve $U_I(t)$ at final time $t = t_f$ using perturbation theory.
Following some references such as this one, since $\lambda$ is small, we can first express the unitary $U_I(t)$ as the power series of $\lambda$: \begin{equation} U_I(t) = \sum_{k=0}^\infty \lambda^k U_I^{(k)}(t). \end{equation} Substituting this into the Schrodinger equation above, we have the following equation: \begin{equation} i\partial_t(U_I^{(0)}(t) + \lambda U_I^{(1)}(t) + \lambda^2 U_I^{(2)}(t) + \dotsc) = \lambda H_I(t) (U_I^{(0)}(t) + \lambda U_I^{(1)}(t) + \lambda^2 U_I^{(2)}(t) + \dotsc). \end{equation} Since the coefficients of each power of $\lambda$ must vanish, we have \begin{align} i\partial_tU_I^{(0)}(t) = 0, \quad i\partial_tU_I^{(k)}(t) = H_I(t) U_I^{(k-1)}(t) \quad \forall k \geq 1, \end{align} where we can assume $U_I^{(0)}(t) = I$ and $U_I^{(k)}(0) = 0$ for all $k$.
Hence, we can iteratively solve the equation from $k=1, \dotsc$, to obtain $U_I^{(k)}(t_f)$. For instance, to solve for $k=1$, we have to solve: \begin{equation} i\partial_t U_I^{(1)}(t) = H_I(t) \quad \leftrightarrow \quad U_I^{(1)}(t_f) = -i\int_0^{t_f} H_I(t) dt. \end{equation} To find $U_I^{(2)}(t_f)$, we can solve: \begin{equation} i\partial_t U_I^{(2)}(t) = H_I(t) U_I^{(1)}(t), \quad U_I^{(1)}(t) = -i\int_0^t H_I(t')dt', \end{equation} and so on. I hope what I explained is mathematically correct, but I am happy to be corrected and learn from my mistakes. Given the set-ups, here are my two inter-connected questions:
$\textbf{Question 1.}$ What is the benefit of using perturbation theory to find the unitary operation $U_I(t_f)$? The reason I am asking this is because it seems to me that to calculate $U_I^{(k)}(t_f)$, one needs to perform $k$-fold integrals, which is essentially the same cost when one tries to solve the unitary operation via Dyson or Magnus series.
$\textbf{Question 2.}$ Is there any special cases (e.g. $H_I(t)$ being a periodic Hamiltonian with the fact that I'm only interested in unitary at final time $t_f$ instead of arbitrary time $t$) where one can solve for $U_I^{(k)}(t_f)$ efficiently without invoking multi-integrals, or efficient iterative algorithm to solve the equation up to the desired order of $k$?
I know that this might be a research-level question, so I don't expect detailed answers. Instead, I would be very thankful if anyone could point me towards related research papers.
