I am trying to obtain a representation of the momentum-space wavefunction $<p'|\alpha>$
Its position space wavefunction is given as $$ <x'|\alpha> = N \exp [-(a+ib)x'^2 +(c+id)x'] $$ where $N,a,b,c,d$ are all real.
I have tried to calculate the following integral using Gaussian integral, or Fourier transform method but both were not easy because of the complex numbers in the exponent.
$$ <p'|\alpha> = \int dx' <p'|x'><x'|\alpha> = \int dx' {1 \over \sqrt{(2 \pi \hbar)}} \exp[-i{p'x' \over \hbar}] N \text{exp} [-(a+ib)x'^2 +(c+id)x'] dx'$$
where I have used $$<p'|x'> = {1 \over \sqrt{(2 \pi \hbar)}} \exp[-i{p'x' \over \hbar}].$$
Can someone give me a hint about calculating indefinite integral with complex exponent?
raccoon
Given your integral:
$$ \langle p'|\alpha\rangle = \int dx' \frac{1}{\sqrt{2 \pi \hbar}} \exp\left(-\frac{i p'x'}{\hbar}\right) N \exp\left[-(a+ib)x'^2 +(c+id)x'\right] $$
You can complete the square within the exponent term involving $x'$: $$ -(a+ib)x'^2 +(c+id)x' = -a(x' - \frac{c+id}{2a})^2 + \left(\frac{(c+id)^2}{4a} - ib\right) $$
Then, you have: $$ \langle p'|\alpha\rangle = N\frac{1}{\sqrt{2 \pi \hbar}} \exp\left(\frac{(c+id)^2}{4a} - ib\right) \int dx' \exp\left[-a\left(x' - \frac{c+id}{2a}\right)^2\right] \exp\left(-\frac{i p'x'}{\hbar}\right) $$
Now the integral looks more tractable as it's a Gaussian integral and you can use the standard results for Gaussian integrals to evaluate it.
Adversing
  • 308
