43
Suppose Stanford Research Systems starts selling a two-level atom factory. Your grad student pushes a button, and bang, he gets a two-level atom. Half the time the atom is produced in the ground state, and half the time the atom is produced in the excited state, but other than that you get the exact same atom every time.
National Instruments sells a cheap knockoff two-level atom factory that looks the same, but doesn't have the same output. In the NI machine, if your grad student pushes a button, he gets the same two-level atom the SRS machine makes, but the atom is always in a 50/50 superposition of ground and excited states with a random relative phase between the two states.
The "random relative phase between the two states" of the NI knockoff varies from atom to atom, and is unknown to the device's user.
Are these two machines distinguishable? What experiment would you do to distinguish their outputs?
Andrew
  • 3,501
8 Answers8
42
These systems are not distiguishable. The average density matrix is the same, and the probability distribution obtained by performing any measurement depends only on the average density matrix.
For the first system, the density matrix is $$\frac{1}{2} \left[\left(\begin{array}{cc}1&0\cr 0&0\end{array}\right)+ \left(\begin{array}{cc}0&0\cr 0&1\end{array}\right)\right].$$
For the second system, the density matrix is $$\frac{1}{2\pi} \int_\theta \frac{1}{2}\left(\begin{array}{cc}1&e^{-i\theta}\cr e^{i \theta}&1\end{array}\right) d \theta.$$
It is easily checked that these are the same.
Peter Shor
  • 11,536
17
Case 1: $\frac{1}{2}\left[\left|0\right>\left<0\right|+\left|1\right>\left<1\right|\right]$.
Case 2, average over phases $0$ to $2\pi$: $$\frac{\int\left[(\left|0\right>+e^{i\theta}\left|1\right>) (\left<0\right|+e^{-i\theta}\left<1\right|)\right]d\theta} {\int\left[(\left<0\right|+e^{-i\theta}\left<1\right|) (\left|0\right>+e^{i\theta}\left|1\right>)\right]d\theta}.$$ The cross terms average to zero because $\int\limits_0^{2\pi} e^{i\theta}d\theta=0$, so it's the same density matrix. If this is really what the different manufacturers deliver, it's not a cheap knock-off.
Peter Morgan
  • 10,016
Let me give some reference that might be useful to make things clear.
It's Landau-Lifshitz, book 5, chapter 5:
The averaging by means of the statisitcal matrix ... has a twofold nature. It comprises both the averaging due to the probalistic nature of the quantum description (even when as complete as possible) and the statistical averaging necessiated by the incompleteness of our information concerning the object considered.... It must be borne in mind, however, that these constituents cannot be separated; the whole averaging procedure is carried out as a single operation, and cannot be represented as the result of succesive averagings, one purely quantum-mechanical and the other purely statistical.
This "twofold averaging" is exactly the reason why the two states cannot be distinguished in any way.
Let me add another nice citation:
It must be emphasised that the averaging over various $\psi$ states, which we have used in order to illustrate the transition from a complete to an incomplete quantum-mechanical description has only a very formal significance. In particular, it would be quite incorrect to suppose that the description by means of the density matrix signifies that the subsystem can be in various $\psi$ states with various probabilities and that the average is over these probabilities. Such a treatment would be in conflict with the basic pronciples of quantum mechanics.
Kostya
  • 20,288
EDIT: Reread it some hours later and found my error. I figured I was doing something wrong. I was applying operations out of order when calculating the conditional probability. It is 1/2 in each case. I'll leave the commentary untouched.
I think the answer is Yes, or at least I'm not entirely convinced the answer is no.
I will provide an example below, but I don't find it very convincing since I just ad-hoc approached it, and don't have a nice "overarching" principle to take away from this. Basically, consider this more as a comment to get discussion going, than a full fledged answer.
The other answers show that the expectation value of measuring the system to be in a particular state is the same. Basically the density matrix of the ensemble is the same, but the density matrix of the first machine only has two possible outputs while the second has an infinite number. Focusing immediately on the ensemble average seems to be throwing away any possibility we have of distinguishing them.
Here's an attempt at distinguishing them:
Machine 1 possible output, only pure states
$|0\rangle$
$|1\rangle$
Machine 2 possible output, any state
$\frac{1}{\sqrt{2}}(|0\rangle + p |1\rangle)$
where $p = e^{i\theta}$ with $0 \le \theta < 2\pi$
Now take some other qubit B (it doesn't matter here physically what it is) of prepared state $\frac{1}{\sqrt{2}}(|0\rangle+|1\rangle)$ to get the product states:
machine 1
$\frac{1}{\sqrt{2}}(|0\rangle+|1\rangle)|0\rangle = \frac{1}{\sqrt{2}}(|00\rangle +|10\rangle)$
$\frac{1}{\sqrt{2}}(|0\rangle+|1\rangle)|1\rangle = \frac{1}{\sqrt{2}}(|01\rangle +|11\rangle)$
machine 2
$\frac{1}{2}(|0\rangle+|1\rangle)(|0\rangle + p |1\rangle) = \frac{1}{2}(|00\rangle+p|01\rangle + |10\rangle + p |11\rangle)$
Now let's introduce an interaction which can cause some interference:
$|00\rangle \rightarrow |00\rangle$
$|01\rangle \rightarrow \frac{1}{\sqrt{2}}(|01\rangle + |10\rangle)$
$|10\rangle \rightarrow \frac{1}{\sqrt{2}}(|01\rangle - |10\rangle)$
$|11\rangle \rightarrow |11\rangle$
now we have
machine 1
$\frac{1}{\sqrt{2}}(|00\rangle +|10\rangle) \rightarrow \frac{1}{\sqrt{2}}|00\rangle + \frac{1}{2}(|01\rangle-|10\rangle)$
$\frac{1}{\sqrt{2}}(|01\rangle +|11\rangle) \rightarrow \frac{1}{\sqrt{2}}|11\rangle + \frac{1}{2}(|01\rangle+|10\rangle)$
machine 2
$\frac{1}{2}(|00\rangle+p|01\rangle + |10\rangle + p |11\rangle) \rightarrow \frac{1}{2}(|00\rangle + p\frac{1}{\sqrt{2}}(|01\rangle+|10\rangle) + \frac{1}{\sqrt{2}}(|01\rangle-|10\rangle) + p |11\rangle)$
$ \ \ \ = \frac{1}{2}(|00\rangle + (p+1)\frac{1}{\sqrt{2}}|01\rangle+(p-1)\frac{1}{\sqrt{2}}|10\rangle + p |11\rangle)$
Now let's do two measurements. First measure the state of B to be 0 or 1, then measure the sate of the atom to be 0 or 1.
Conditional probability on the ensemble:
Given that we find B in state 1, what is the probability of finding the atom in state 0?
machine 1
(1/2) x 1 + (1/2) x (1/3) = 4/6
machine 2
$\frac{\frac{1}{2}(p-1)^2}{\frac{1}{2}(p-1)^2 + p^2} = \frac{\frac{1}{2}(2 - 2\cos\theta)}{\frac{1}{2}(2 - 2\cos\theta) + 1} = \frac{1 - \cos\theta}{2 - \cos\theta}$
Now averaging over $\theta$
$\mathrm{Prob} = \frac{1}{2\pi}\int_0^{2\pi}\frac{1 - \cos\theta}{2 - \cos\theta} d\theta = 1 - \frac{1}{\sqrt{3}}$
Now, it is quite possible I've made a mistake here. But my main point is that the other answers seem to be throwing away the useful information to obtain solely an average of the initial output states. As the answers stand now, they do not mathematically convince me that we can never obtain an effect by adding interactions and multiple measurements with conditional probability or maybe 'weak' measurements, since individually the states have much different density matrices. Hopefully I didn't make a mistake above, but even if I did, I'd still very much like to hear more in the other answers beyond what is currently written. This is a fascinating question, so I'm quite interested in discussing this further.
Edward
  • 2,150
Perhaps the machine described here can actually be built. Let me propose a heated flask containing a 50-50 mixture of gaseous, monatomic carbon-14 and nitrogen-14. When you push a button, a pinhole opens up and allows exactly one atom to escape. Is it: either a carbon atom or a nitrogen atom, with 50% probability, or is it an atom in a 50-50 superposition of the carbon/nitrogen states?
EDIT: Let's do this just a little differently. Let's prepare a bottle of pure, gaseous monotomic carbon-14 and then wait for 7000 years. Now let's let an atom out of the bottle. Is it a carbon atom, a nitrogen atom, or a 50-50 superposition of both?
The weight of expert opinion in the answers posted thus far seems to indicate that these two descriptions are experimentally indistinguishable. I suspect this is correct, although it's a funny conclusion that flies in the face of the common-sense belief that an atom is either carbon or nitrogen, but not both. However I think two stipulations ought to be noted:
  1. I can see no reason why a given atom ought not to appear in an 80/20 superposition, so long as the long-term average is 50/50.
  2. I don't believe the machine is actually constructible because I don't think there is a mechanism which can reliably produce exactly one atom at a time. You never quite know just how many atoms you've let out, and that introduces enough uncertainty in the measurement to avoid any of the glaring contradictions that seem to be present.
EDIT: When Andrew posted this question, he promised a follow-up question. It's six months later and I haven't seen the follow-up. So here's what I think the follow up was going to be:
Suppose you have a gas in equilibrium. According to thermodynamics, the probability of an atom being in a given state is given by an exponential function of the energy. So, according to Copenhagen, we have atoms in different energy eigenstates which make random transitions from one state to another, emitting or absorbing photons when they make transitions. Question: Is there a way to experimentally distinguish this model from an alternate model where all the atoms are in continuously varying superpositions of states, radiating or absorbing continuously as the charge distribution of those superpositions oscillates like tiny antennas?
If Andrew is out there, I wonder if this was his follow-up question?
Marty Green
  • 4,289
The density matrices in both cases are identical. If quantum mechanics is exactly linear, both states ought to be indistinguishable. But if there are some slight nonlinearities in the time evolution, we ought to be able to distinguish between them in principle. But you have to realize nonlinearities in quantum mechanics lead to all sorts of problems, which is why most people assume quantum mechanics is exactly linear.
QGR
  • 2,377
I believe that in the SRS case that 50% of the atoms will eventually emit a photon, and in the NI case, all the atoms will eventually emit a photon. To distinguish them, emit a large, known number of atoms from each and measure the number of photons. SRS will have N/2 and NI will have N.
It seems the density matrix explanations have left out the time dependence.
Dr. Nate
  • 477
-4
This is such a nice philosophical question with such a neat resolution that I can't resist dropping a comment. The reduced density matrices of the atom are the same for Stanford and National, but quantum mechanics is irreducibly holistic. The wave function describes the entire universe. If the atom was prepared by Stanford, it will be entangled with traces of the environmental record in Stanford in a particular way, but if it was prepared at National, it will be entangled with traces at National in a different but still specific way. Holistically, there is indeed a difference. To suppose the atom can be considered in isolation from the rest of the world is a major fallacy in quantum mechanics.
