I was just trying to confirm to myself that the following density operator
$$\rho(t) = e^{-iHt/\hbar} \rho(0) e^{iHt/\hbar}$$
fulfills the Liouville-von Neumann equation:
$$\frac{d}{dt}\rho(t) = - \frac{i}{\hbar} [H,\rho(t)]$$ where $[H,\rho(t)]$ denotes the commutator of the Hamiltonian with the density operator here. I only have to take the derivative of $\rho(t)$ in order to plug it in, but although the answer is probably trivial, I am struggling at the moment as I don’t really know how to take the derivative of this expression (there are several operators acting here, so I am not sure how to apply the product rule here). Can someone please help me?
The product rule works essentially as you think it might. You just must be careful about the commutation of of operators. For example, $$\frac{d}{dt}\big(AB \big) = \left(\frac{d}{dt}A\right) B + A \left(\frac{d}{dt}B\right) \neq \left(\frac{d}{dt}A\right) B + \left(\frac{d}{dt}B\right)A$$
If you would like a rigorous description of operator differentiation, we need to be more precise. Let $A:t \mapsto A(t)$ be a family of operators on some (for now, finite-dimensional) Hilbert space $\mathscr H$ which are indexed by a continuous variable $t$. The derivative $A'(t)$ is the operator such that, for arbitrary $\psi\in \mathscr H$,
$$A'(t) \psi = \lim_{\epsilon\rightarrow 0} \frac{A(t+\epsilon)\psi - A(t)\psi}{\epsilon}$$
assuming that this limit exists. Alternatively, $A'(t)$ is the operator such that $$\displaystyle \lim_{\epsilon \to 0} \left\Vert \big[A(t+\epsilon)- A(t) - \epsilon A'(t)\big]\psi \right\Vert \longrightarrow 0$$ for all $\psi\in \mathscr H$. Therefore, as a computational tool we may take an expression which depends on $t$, substitute $t\rightarrow t+\epsilon$, make first order replacements of the form $f(t+\epsilon) = f(t) + \epsilon f'(t)$, and then read off the term proportional to $\epsilon$ at the very end.
For example, $$A(t)B(t) \rightarrow A(t+\epsilon)B(t+\epsilon) \rightarrow \big(A(t) + \epsilon A'(t) \big) \big( B(t) + \epsilon B'(t)\big)$$ $$\rightarrow A(t) B(t) + \epsilon \underbrace{\bigg(A'(t) B(t) + A(t) B'(t)\bigg)}_{\frac{d}{dt} A(t) B(t)} + \epsilon^2 A'(t)B'(t)$$
Claudio
  • 356
  • 15
Albatross
  • 72,909
This is just a product rule.
Take $\rho(t) = e^{-iHt/\hbar} \rho(0) e^{iHt/\hbar}$ and use the product rule:
$$\frac{d}{dt}\rho(t) = \frac{d}{dt}[e^{-iHt/\hbar} \rho(0) e^{iHt/\hbar}]$$
This is just:
$$=\frac{d e^{-iHt/\hbar}}{dt} \rho(0) e^{iHt/\hbar} + e^{-iHt/\hbar}\rho(0)\frac{d e^{iHt/\hbar}}{dt} $$
Which is:
$$ =\frac{-iH}{\hbar}e^{-iHt/\hbar} \rho(0) e^{iHt/\hbar} + e^{-iHt/\hbar}\rho(0)e^{iHt/\hbar}\frac{iH}{\hbar} $$
Which by definition of $\rho(t)$ is just:
$$=\frac{-iH}{\hbar}\rho(t) + \frac{iH}{\hbar}\rho(t) = \frac{-i}{\hbar}[H,\rho(t)]$$
Which is indeed what you wanted!
MrDBrane
  • 971
