-2
I've recently delved back into some alternative interpretations of quantum field theory.
While Richard Feynman often emphasized that calculations were sufficient and discouraged fixation on the "true" nature of events, his Nobel Lecture suggested exploring diverse avenues for advancing theoretical physics. It's pertinent to note that Feynman Diagrams, known for their utility in calculations and visualization, are isomorphic to the rigorous Schwinger-Tomonaga formulation, as established by Dyson.
My familiarity with QFT extends to the Lehmann–Symanzik–Zimmerman (LSZ) reduction formula derived from Lagrangian formalism, as well as the equivalent results obtained via the path integral formalism.
The proposed reinterpretation below predominantly abandons the particle-centric view and instead focuses solely on fields which must be in line with the rigorous Schwinger-Tomonaga formulation, with which I am not familiar.
I'm particularly curious whether Schwinger-Tomonaga- Dyson's rigorous formulation serves merely as another way of calculating amplitudes or if it indeed imparts insights into the physical processes underlying particle scattering—specifically, the moments before, during, and after.
The proposed reinterpretation posits that, during particle scattering, the energy-momentum of incoming fields interacts with quantum fields existing in the vacuum.
Unlike the traditional view involving virtual particle exchange seen in Feynman Diagrams, this interpretation posits that the interaction primarily occurs between the energy of incoming fields and vacuum quantum fields in a localized spacetime region.
This energy transfer excites the lowest energy fields in the vacuum into becoming real observed outgoing particles.
Does this reinterpretation, which deviates from the conventional portrayal through Feynman diagrams, offer a better comprehension of the physical process?
Could it prompt a reevaluation of long standing assumptions? Despite being rooted in the same QFT framework, does this reinterpretation indicate a promising path to fresh insights into the fundamental physical processes?
In summary, this question aims to determine the compatibility of the presented reinterpretation with established QFT interpretations which use virtual particles and the potential implications for advancing our understanding of fields interactions. The traditional concept of virtual particles is sidelined, with a focus on fields, rather than virtual and real particles as the primary entities driving interactions.
References:
Feynman, R. P. (1965). The Character of Physical Law. MIT Press.
Dyson, F. J. (1949). The radiation theories of Tomonaga, Schwinger, and Feynman. Physical Review, 75(3), 486.
Lehmann, H., Symanzik, K., & Zimmermann, W. (1955). On the formulation of quantized field theories. Il Nuovo Cimento, 1(2), 205-225.
VVM
  • 585
all possible outgoing particles are actually pre-existing as virtual particles, matter and anti matter, within the vacuum.
Consider the Higgs particle with a mass-energy of 125 GeV. If you have a virtual Higgs just sitting there in what you refered to as a "vacuum", it's going to have this energy. Energy fluctuations in the vacuum are possible, but they are constrained by the Heisenberg uncertainty principle:
$$\Delta E \cdot \Delta t \sim h$$
where $\Delta E$ is the uncertainty in energy, $\Delta t$ is the uncertainty in time and $h$ is the planck constant. This means, if a Higgs particle would suddenly appear, the energy would shift by $\Delta E = 125$ GeV, so the time before it decays again would be at most
$$\Delta t \sim \frac{h}{\Delta E} \sim 10^{-26} \text{ s}$$
The Higgs can't exist for longer, because this would violate the uncertainty principle. The same is true for all other virtual particles (lighter ones can exist for a little longer).
So in my mind, this idea of virtual particles just "sitting" in the vacuum awaiting energy to turn into real particles doesn't work, because the mass-energy is always there.
Also note that Feynman diagrams were never meant to provide any deep insight into the nature of quantum interactions. They are just a useful tool for calculations, nothing more.
