This is a follow-up to a previous post of mine post. In that post, we concluded that a beam cannot be held in place by an application of normal forces in only one location if that location is off the center of mass. That makes complete sense.
In light of that, I am wondering how we can explain the following modified scenario. Suppose we have a rectangular beam glued to the wall, as depicted below.
Assume the beam is uniform in density and is of mass $m$. It's length is $L$ and height (really it's the width here) is $H$. The resultant force due to gravity will be $\vec{W} = -mg\hat{y}$ at the center pulling the block downward. The glue has to keep the block from falling, so there ought to be forces on the left side of the block.
Now there can be a combination of horizontal forces and vertical forces applied at the left side.
My first question is, is this an underdetermined problem, meaning more needs to be specified about the contact between the glue and the side of the block? If so, I wonder how that could be dealt with. The example in this post shows that this is a real possibility.
My main question is, since the gravitational force acts downward on the block, there has to be a force upward on the left side by the glue. However, in the post I linked at the start of this post, we can't add only one off-center force acting upward without creating a net nonzero torque. So in terms of forces, how exactly is it possible that the glue can keep the block in place if adding a vertical force upward at the left will lead to a nonzero torque?
Note that my block has a height/width this time, because I think this problem would be unsolvable if it were a 1D rod. However, I'm still unsure how the issue can be resolved.
