In quantum mechanics of discrete systems, a state is represented by a linear combination of $n$ basis states: $$|\Psi\rangle = \sum_{i=1}^n \psi_{i}|\psi_i\rangle$$
In a basis like position, where $n\rightarrow\infty$, the state is represented by an integral:
$$|\Psi\rangle = \int\text{d}x\, \psi(x)|x\rangle$$
I understand the intuition in replacing an infinite sum with an integral and how Riemann sums converge to integrals generally, but don't understand where the factor of $\text{d}x$ comes from that makes this replacement valid.
How does the continuous definition follow from the discrete definition, and does the factor of length change the state's units?
In discrete systems, the basis states are usually normalized to unity: $\langle\psi_i|\psi_j\rangle = \delta_{ij}$. In contrast, in the continuous case the states are normalized by Dirac delta function. For example, for the 1D particle \begin{equation} \langle x|x'\rangle = \delta(x-x'), \end{equation} which means that the norm of the state $|x\rangle$ is $\delta(0) = \infty$. This intuitively explains the emergence of infinitely small $dx$ in the integral.
A link between the continual and discrete cases can be made by considering a lattice approximation for the continuum as @LPZ commented. Assume that the particle on a line can occupy only discrete sites $x_k = k\Delta x$. For each site, there exists a corresponding ket vector $|x_k^{discr}\rangle$ normalized by unity: \begin{equation} \langle x_k^{discr} | x_{k'}^{discr}\rangle = \delta_{kk'}, \end{equation} Arbitrary ket vector can be decomposed into a sum \begin{equation} |\psi\rangle = \sum_k c^{discr}_k |x_k^{discr}\rangle, \end{equation}
where $\sum |c^{discr}_k|^2 = 1$. We would like to take the limit $\Delta x \to 0$ and replace the sums with the integral with the prescription \begin{equation} \sum_k \Delta x F(x_k) \to \int dx F(x) \end{equation} However, it is necessary to change the norms of the basis vectors and expansion coefficients for that.
First, the normalization of $|x_k^{discr}\rangle$ differs from the delta-function normalization which should be in the continuous limit. To fix this, let us introduce new rescaled ket vectors $|x_k\rangle = \frac{1}{\sqrt{\Delta x}}|x_k^{discr}\rangle$. Their scalar product is \begin{equation} \langle x_k | x_{k'}\rangle = \frac{\delta_{kk'}}{\Delta x} \to \delta(x_k - x_{k'}) \end{equation} which approaches delta-function at $\Delta x \to 0$.
Also, let us rescale $c^{discr}_k$ as \begin{equation} c^{discr}_k = \sqrt{\Delta x}c(x_k). \end{equation}
With new $|x_k\rangle$ and $c(x_k)$, the decomposition of $|\psi\rangle$ becomes \begin{equation} |\psi\rangle = \sum_k \Delta x \cdot c(x_k) |x\rangle \to \int dx \,c(x) |x\rangle, \end{equation} as usually defined for the continuous case. The coeficients $c(x)$ are also normalized: \begin{equation} \sum \Delta x |c(x_k)|^2 \to \int |c(x)|^2 dx = 1. \end{equation}
E. Anikin
  • 1,123
