In static spherically symmetric spacetime with metric $$ds^2=e^{2\nu}c^2dt^2-e^{2\lambda} dr^2-r^2 (d\theta^2+\sin{\theta}~d\phi^2)\equiv \delta_1~c^2 d\tau^2 \tag{1}$$ the geodesic equation in equatorial plane ($\theta=\pi/2$) reads $${e}^{2\nu+2\lambda}~\frac{\dot{r}^2}{c^2}=k^2-{e}^{2\nu}~(\delta_{1}+\frac{l^2}{c^2 r^2})\equiv k^2-V(r) \tag{2}$$ where the constants of motion are defined as $$k\equiv {e}^{2\nu}~\dot{t},~~~l\equiv r^2~\dot{\phi}~~~.$$ Correspondingly to space-, null- and timelike geodesics $\delta_{1}$ can take values $~-1,0,1$ . For circular geodesic it applies $\dot{r}=\ddot{r}=0$. Hence, a geodesic of curvature radius $r_{0}$ has constants $$k^2=\delta_{1}\frac{e^{3\nu}_{0}}{e^{\nu}_{0}-r_{0}~\partial_{r}{e^{\nu}_{0}}},~~~l^2=\delta_{1} c^2 \frac{r_{0}^3~\partial_{r}{e^{\nu}_{0}}}{e^{\nu}_{0}-r_{0}~\partial_{r}{e^{\nu}_{0}}}~~~. \tag{3}$$ For the special geodesic defined through condition $e^\nu(r_0)~=~0$ they result in $$k^2=0,~~~l^2=-\delta_{1}~ c^2 r_0^2~~~. \tag{4}$$ The second equation seems to indicate that such a geodesic can be followed only by spacelike particle ($\delta_1=-1$) with zero rest energy ($k^2=0$) and non-vanishing momentum ($l^2\geq 0$) or timelike particle $(\delta_1=1)$ with imaginary angular momentum ($l^2\leq 0$).
Assuming the first case the effective Potential reads $$V=e^{2\nu}~(-1+\frac{r_0^2}{r^2}) \tag{5}$$ and satisfy $$V(r_0)=\frac{dV}{dr}(r_0)=\frac{d^2V}{dr^2}(r_0)=0. \tag{6}$$ Thus, that special geodesic represents the innermost circular stable orbit (ICSO).
However, there only known particles in General Relativity satisfying theses conditions are transcendent tachyons. While at the same time the equation $e^{\nu}(r_0)=0$ defines event horizon of the curvature radius $r_0$, the question arises if one could interpret the event horizon as a transcendent tachyon.
Although such interpretation would contradict the prevailing understanding of event horizon as an imaginary 2-sphere it would have some other merits. Particles colliding with transcendent tachyon reflect without energy change but with charge switch, see Fig.5 in “Particles beyond the light barrier”. That has some resemblance to so called "firewall" theory. Another interesting point is that transcendent tachyon geodesic defined by equation (4) is stable. The corresponding effective potential has minimum there and the whole process of black hole formation could be understood as spontaneous symmetry breaking phenomenon, see Fig. 4 in “Tachyons and Solitons in Spontaneous Symmetry Breaking in the Frame of Field Theory”.
Appendix
I wanted to study the parametric stability of perfect fluid (sphere) spacetime using the geodesic equation and the effective potential $V(r)$. The parameter is $\alpha\equiv r_S/R$. For the congruence of radial geodesics $V(r)=e^{2\nu}$. In the case of a Schwarzschild constant density star, the potential for $\alpha<8/9$ (green line) has a regular ($\sim r^2$) minimum in the center, which degenerates ($\sim r^4$) for $\alpha=8/9$ (red line) and transforms to a local maximum for $\alpha>8/9$ (blue line). Quasi-statically, the black hole formation process looks like a classical "pitchfork" catastrophe. The former central minimum moves outwards until $\alpha=1$ is reached. In terms of radial geodesics, the local minima ($r_0$) are stable and the local maximum is unstable. I wanted to see the corresponding stability of circular orbits starting at different $r_0$ ( minimums) and their possible physical interpretation. After all, the minimum at $r_0(\alpha)$ represents a moving event horizon of curvature radius $r_0(\alpha)$. enter image description here
JanG
  • 2,237
I think that the big point you are missing with this analysis is that the event horizon is a 3 dimensional submanifold or hypersurface, not a 1D worldline (geodesic or otherwise). The fact that a hypersurface contains some kind of geodesic does not make that hypersurface that kind of geodesic.
As a directly relevant counterexample, consider a simple electromagnetic plane wave. This is the prototypical null surface. It should be immediately obvious that a plane wave also contains “transcendent tachyon” geodesics. Nevertheless, the hypersurface is a null surface and it is physically formed by lightlike particles.
In fact, since tachyons in principle can accelerate, it is possible to describe any hypersurface as being composed of transcendental tachyons.
Dale
  • 117,350
The real problems in this topic arise when you want to reconcile the events with quantum mechanics (qm). But to understand and appreciate the problems it is best to first ignore qm and learn about the details of gravity and black holes using only classical (i.e. non quantum mechanical) physics - as you are doing now. Indeed, one finds that black holes with matter present are unstable, because hatter will fall in while nothing can come out. Unless you add thermodynamics: entropy can only increase! But then you’ll find that qm is inevitable ...
G. 't Hooft
  • 5,521
