We are given five idential spin-half particles in Linear Isotropic Harmonic Oscillator potential. It is required to find the degeneracy of the ground state of the system.
I understood the approach given in the Energy degeneracy of two particles in isotropic harmonic potential
But I am not sure how to get spin wave function for 5 identical particles. I mean currently, I do not have working knowledge of how to get Clebsch Gordan coefficients and things like that.
But generally, I have seen some of my collegues use combinatorial approach to deal with such problems. I am not finding this combinatorial approach in any textbook, this is why I suspect whether it is valid or not.
What they do is, Energy degeneracy of two particles in isotropic harmonic potential , for this example, for spin-1/2 particle to find degeneracy for first excited state is, after first energy level having three splits (100),(010),(001) , each split can have two possible states. So, it is $3 \times 2=6$ and also first electron in ground state can have 2 possible states $2 \times 1 = 2$. So, total degeneracy $6 \times 2 =12$.
Similarly, for second excited state, they divided it into two sub-possibilities. One particle in ground state, other in second excited state. Whereas, second possibility is, both particles is in first excited state. And we need to add both the possibilities.
For first case, we have 2 states spin up and down for particle in ground state, and $6 \times 2=12$ possible states for particle in second excited state. Because there will be 6 split for second excited energy level in 3d harmonic oscillator. Therefore, for both particles, there will be $12 \times 2=24$ degeneracy.
If both particles kept in first excited state, then there will be $^6C_2 = 15$ possibilities.
So, total $15+24=39$ degeneracy. Answer matches with what obtained in the given link.
Now, my objection with this method is, they do not even consider wave function symmetrization or anti-symmetrization to calculate degeneracies.
By the way, coming back to the original question posed above, the answer of above question posed is 20. They got this by taking two particles at ground state and now three particles remaining to put in 6 available states in first excites state. So, $^6C_3 = 20$. Here also how can we take wave function anti symmetrization into account ? Also, answer $20$ is given correct one. But I am not sure whether it is actually correct or not following standard symmetrization constraint problem as described in the link I put above.
Is combinatorial approach acceptable one in general?
Any suggestion would be helpful.
