I have two questions regarding (possibly counter intuitive results) Schrodinger equation and its application to two (strictly hypothetical) scenarios.
  1. Consider the 1D potential $V(x) = - \frac{\alpha}{|x|}$, which is an attractive one. As it is attractive, after a sufficiently large amount of time I'd expect the probability density of finding the particle at $x=0$ (center) to be higher than that anywhere else. I hope it is reasonable to expect such a thing.
    But the solution according to Schrodinger equation is (as given in this answer) is $$u_n(x,t) \sim \lvert x\rvert e^{-\lvert x\rvert/na} ~L_{n -1}^1\biggl(\frac{2\lvert x\rvert }{na}\biggr) e^{-E_nt/\hbar}$$ Consider the amplitude at $x=0$ $$\lvert u_n(0,t)\rvert = 0$$ which I think is contradictory to our reasonable expectations based on intuition. I'd appreciate some comments on why it is counter intuitive.
  2. Consider the particle in box problem and according to Schrodinger's equation, in almost all energy states the probability of finding the particle close to the boundaries is zero. Now instead of intuition (which is not predicting anything) I'd give a practical example where it is quite contradictory. (Pardon me if this example is not suitable, I am learning and I'd love to know why it isn't intuitively not suitable). Consider a metal conductor, I guess its an example for particle in a box as the potential inside is zero and we know that the charge is usually accumulated at the edges of the conductor.
EDIT
An interesting thing to add. The probability density vanishing at center does not seem to arise in 3-D hydrogen atom. Check the wave function of 1s orbital of Hydrogen atom, it of the form $\psi_{1s}(r) = a e^{-kr}$, where $k$ and $a$ are some constants and $r$ is the radial distance from nucleus.
Rajesh D
  • 2,192
5 Answers5
Question 1:
Your intuition that in the probability density of finding the particle should be the highest at $x=0$ (when it is in the ground state, to be precise) must be correct, but the solution you quoted is faulty.
I read the reference from the answer you linked. There, what the authors really have done is to solve the Schrodinger's equation for $V(x)=- \frac{1}{x}$ and $V(x)=+\frac{1}{x}$ separately (with no restriction on the range of $x$ for either case) to obtain the bound-state solutions $\psi_{+}(x)$ and $\psi_{-}(x)$. Then, they claim that the full solution is such that $\psi(x)=\psi_{+}(x)$ for $x>0$ and $\psi(x)=\psi_{-}(x)$ for $x<0$.
However, what they have solved is a totally different problem than they had originally intended to. Most importantly, the potentials $V(x)=\mp\frac{1}{x}$ have infinite barriers at $x=0^{\mp}$. Therefore, we can expect that a particle bound to the potential $V(x)=- \frac{1}{x}$ ($+\frac{1}{x}$) on the $x>0$ ($x<0$) side can never penetrate into the other side. You can check this fact mathematically by Fourier transforming the momentum-space wave function from Eq. 13 in the reference. You'll see that $\psi_{+}(x)$ completely vanishes for $x\le 0$ and $\psi_{-}(x)$ for $x\ge 0$. This is certainly not what would happen for $V(x)=-\frac{1}{|x|}$.
In the same paper, other people's results are also mentioned. Most notably, some of them apparently obtained eigenfunctions associated with a continuum of negative-energy spectrum, although the authors of this paper consider them unphysical. IMHO, this sick negative-energy continuum probably does exist, and what it tells us is not that we should discard the corresponding solutions while keeping more well-behaved ones, but that Schrodinger's equation for $V(x)=-\frac{1}{|x|}$ is a fundamentally sick problem in the sense that the electron can really fall indefinitely down to the infinitely deep potential well.
Question 2:
Coulomb interaction between electrons in a metal is screened and becomes short-ranged. This is at least a part of the reason why non-interacting electrons in an infinite potential well can be a reasonable model of a metal for certain purposes.
On the other hand, charges accumulating at the boundary of a metal are "excess" charges. Coulomb repulsion between them is not screened. The non-interacting model by no means contains this kind of physics, but may still be used to describe the interior of the metal in which the Coulomb interaction is screened.
higgsss
  • 2,890
Just to show that the first situation is not that uncommon: the gravitational force is attractive, yet the probability of finding a planet inside the sun is tiny. (of course, who would be brave enough to go check, right?)
The semi-intuitive explanation is this: the particle has a certain amount of energy and the force field is conservative. So no energy is lost. However, if the particle were at the center of the system, at rest, it would have the lowest energy possible. No potential energy (if we set the zero for potential energy at the center, which is common) and no kinetic energy since the particle isn't moving. So basically it's energy conservation that prevents a particle in an attractive potential from settling down at the center.
For your second case: the potential inside a metal isn't completely zero. The conduction electrons are still influenced to some degree by the ions (and each other). Otherwise, every metal would be a superconductor at any temperature. And in the absence of an exterior potential, I don't think the electrons accumulate at the edges of the metal. They move through the lattice of ions as a nearly-free gas, their motion modulated (slightly) by the (motions of the) ions.
Wouter
  • 5,527
Once again I would like to emphasize that when we go to the quantum regime, the concept "particle" does not carry one to one from the classical regime.
In the classical regime a particle is defined by its center of mass and the position and velocity of the center of mass, but those are not its only attributes. It is also defined by the volume it occupies and the mass density per unit volume.
In the quantum regime two things happen, an "elementary particle" can be particle like, defined by the first sentence in the above paragraph, with and (x,y,z,t) and a (p_x,p_y,p_z,E) four vector ( in units where c=1), identical to the definition of a classical regime particle. BUT it has no volume or mass density, it is a point particle. The second difference is that an elementary particle may display a wave behavior, characterized by experimentally observed interference patterns. This is not the behavior of macroscopic particles.
The quantum mechanical equations developed to fit this observed behavior, the particle like and the wave like nature, and the solutions of the equations give us the probabilities of finding a "particle" at a specific space time point, which probability has wave like properties. These are static solutions for time independent potentials. They do not develop over time, fortunately, otherwise we would not be here since atoms depend on this stability. ( rather the solutions of the equations describe the stability of atoms).
So yes, there is a probability for an electron of an S state to find itself in the middle of the nucleus, and that is how electron capture happens and nuclei are transformed to lower Z. It is a tiny probability, considering that the size of the nucleus to the size of the atom is orders of magnitude smaller, but it happens, and is well described by the appropriate solutions of the QM system.
Now conductors are complicated. The conduction electrons are shared by all the nuclei because there are common energy layers. It cannot be modeled by a square well potential.
anna v
  • 236,935
Intuitively (I.e. classically), for a particle in an attractive 1D potential one would expect the probability density to be maximal at positions where the particle comes to a stop, i.e. at positions where it bounces back. The opposite is also true: where the potential is deepest, the particle will spend less time and one would intuitively expect the probability density to be minimized.
For particles with precisely zero angular momentum in a rotationally symmetric 2D (or higher dimensional) potential (the alternative case considered by OP) the behavior is different. This is due to the fact that the zero angular momentum constraint causes the origin (the point where the potential is deepest) to act as a "focal point": the particle moves quickest at this point but is guaranteed to pass through this point whereas most positions away from the origin will be missed by the particle.
Considering either the strictly 1D classical case or any higher dimensional classical case in which the angular momentum can impossibly be defined with infinite precision, I would defend the position opposite to that stated in the question: observing a maximum probability density for finding a particle at the deepest point of the potential would be counterintuitive.
Now turning to the quantum case: it is not correct to assume that the ground state probability distribution for a point particle in a potential will always attain a non-zero value at the location of the classical ground state. A straightforward counter example is provided by any 1D potential V(x) that is unbounded for negative x, and monotonically increasing for positive x.
Johannes
  • 19,343
In one dimension, motion in a Coulomb-like attracting potential $U=-\frac{\alpha}{|x|}$ is quite ill-defined. I'll now try to explain this for classical particles, then will say some words about quantum mode.
Let's consider two cases:
  • 3D motion of a particle nearly free falling into the attracting center, but with nonzero angular momentum $L$.
In this case we know from Kepler laws that the solution is an elliptic trajectory. Its area will go to $0$ as $L\to0$, leaving major axis length finite. Thus, in the limit of $L\to0$ we have a free falling particle with trajectory being a straight line, and, surprisingly, the particle will effectively repulse from the attracting center after reaching it. But this motion is nothing than 1D motion in Coulomb-like potential, and the particle doesn't ever go past attracting center, having asymmetric trajectory.
  • 1D motion in a more general potential $U=\frac{-\alpha}{\sqrt{x^2+\varepsilon^2}},$ which will become usual Coulomb-like potential when $\varepsilon=0$.
Let $\varepsilon\ne0$ and starting speed of particle $v_0=0$. At $x\approx0$ the potential behaves like a harmonic oscillator, so the particle will go through it. Eventually the particle will slow down at the point opposite to starting point, and continue moving in the opposite direction. Now make $\varepsilon$ smaller. The particle will still move in a trajectory, symmetric with respect to origin. As you take the limit $\varepsilon\to0$, you'll get your particle moving in a symmetric trajectory.
You can see that both cases show one-dimensional motion in Coulomb-like potential, but they arrive at contradicting results. So, one should draw the conclusion that the solution of the problem depends on from which side you take your limit: either nearly free-falling particle with $L\to0$, or nearly Coulombic potential with $\varepsilon\to0$.
When you take quantum equation, i.e. Schrödinger equation, you will in fact arrive at similar results with both approaches because you no longer have definite trajectories, and your approach in the first case is putting all the 3D system into a quantum wire with attracting Coulombic center in the middle and shrinking its walls.
The result in both cases in quantum mode will be that your ground state energy is unbounded from below as you approach 1D Coulombic regime, and the wavefunction will converge to something like a Dirac delta function, though the limit might not be strictly it. Of course, this result is quite nonphysical: you need infinite energy to excite the particle.
As for the solution given in the answer you link to, I'd say it's at least incomplete: it doesn't include boundary conditions on joining of $u^+$ and $u^-$ functions, and even if it does give you the solution, it doesn't include ground state.
Ruslan
  • 30,001
  • 70
  • 154
