Consider the case of a free particle with wavefunction $$\Psi(x, t=0) = \left(\frac{a}{\pi}\right)^{1/4} e^{-ax^2/2} \quad a>0$$ Prove that the uncertainty product $(\Delta x)(\Delta p)$ is parabolic close to $t=0$.
Attempt: I basically want to show that for small $\delta t$ we have $(\Delta x)_{\delta t}(\Delta p)_{\delta t} = \frac{\hbar}{2} + b\cdot \delta t^2$, for $b>0$. My only thought at this point is to consider the Taylor expansion of the uncertainty product as a function of time and show that $\frac{d}{dt}(\Delta x)(\Delta p)\; \big|_{t=0} = 0$ and that $\frac{d^2}{dt^2}(\Delta x)(\Delta p)\;\big|_{t=0} > 0$ (or just $\neq 0$ since the uncertainty principle will guarantee that it's positive). Is this the right approach? If so, how do I proceed?
I also tried to explicitly calculate $\Psi(x,t)$ and calculate the product, but the calculations involved are very tedious.
I'm sorry if my question is not appropriate, but I'm quite new to quantum mechanics (and physics in general).
I am not sure if you have been taught the simpler, Heisenberg picture, so I'll stick to the Schroedinger one, born messier, as you observe.
  1. As WP suggests, show $$\Psi(x, t) = \left(\frac{a}{\pi}\right)^{1/4}\frac{ e^{-ax^2/2(1+i\hbar at/m)} }{\sqrt{1+i\hbar at/m}}. $$ There are 39.7 methods to do this, but my favorite is the free propagator.
  2. Show $\langle x\rangle = \langle p\rangle =0$.
  3. Show $$\langle x^2 \rangle_0 \langle p^2\rangle_0 = \hbar^2/4 .$$
  4. "Compute" $$ \frac{\langle x^2 \rangle \langle p^2\rangle }{\langle x^2 \rangle_0 \langle p^2\rangle_0 }= 1+(\hbar at/m)^2. $$ Just scale the variables. You need not compute $\int\!\!dx ~e^{-x^2} x^2$ anymore.
  5. Take the square root and expand in t to lowest order.
None of my business, but the 500kg Gorilla in the room is the behavior at large t, where the variance product, uncertainty, increases linearly with t.
Cosmas Zachos
  • 67,623
