Suppose a particle’s wavefunction satisfies the 1d time-independent Schrodinger equation with potential $U(x)$ and that its ground state is known to be $\psi_0(x)$.
The particle is in the state $\psi_0$ when at time $t = t_0$ the potential is suddenly changed from $U(x)$ to $V(x)$ (e.g., this could correspond to a potential well doubling in size). Suppose I know the stationary states of this new potential and their corresponding energy eigenvalues; call them $\phi_n$ and $E_n$ respectively (say).
What is the expression for the probability of finding a particle in the old ground state $\psi_0$ immediately after time $t=t_0$?
I know the new wavefunction is
$\phi(x,t) = \sum_{n=0}^\infty c_n\phi_n(x)e^{-iE_nt/\hbar}$ where the $c_n$'s are determined from the normalisation condition using Fourier.
Not sure how to take it from here. Any help appreciated.
Vadim
  • 115
The probability of the particle being in the ground state of $U$ at $t=t_0$ is $1$, and the evolution of the wave function is continuous. So in the limit $\lim_{\Delta t\rightarrow 0}t = t_0 + \Delta t$, the probability of finding it in the ground state of $U$ tends to $1$.
What is happening is that at $t=t_0$, the wave function is the ground state eigenfunction of the Schrödinger equation for potential $U$, but when the potential is changed to $V$, that will in general not be an eigenfunction of the new Schrödinger equation. So to get the time evolution for $t > t_0$, you have to write the old eigenfunction $\Psi(t_0, x) = \psi_0(x)$ as a linear combination of the new eigenfunctions such that $\Psi(t_0, x) = \sum_n c_n \phi_n(x)$, with $c_n = \langle\phi_n | \psi_0\rangle$, and then each of the $\phi_n$ time evolves with a phase factor of $e^{-iE_n (t - t_0)/\hbar}$, so for $t>t_0$ we get $\Psi(t, x) = \sum_n c_n\phi_n(x)\,e^{-iE_n (t - t_0)/\hbar}$. In the limit of $t\rightarrow t_0$ this obviously recovers $\psi_0(x)$ by construction.
noah
  • 10,404
  • 29
  • 39
