I've got a question regarding the position operator. As far as I learned it, the position operator simply gets defined by saying:
$\hat{x} \ \psi(x,t) = x \ \psi(x,t)$
And I also learned that the momentum representation of the position operator is defined as ($p,k$ used interchangeably):
$(\hat{x})_p = i \frac{\partial}{\partial k}$
I'm a bit confused about that. Why is this the "momentum" representation? Let's say I have a plane wave
$\psi(x,t)=e^{i(kx-\omega t)}$
If I wanted to define the position operator, I would just do it like that:
$\hat{x} e^{i(kx-\omega t)} = -i \frac{\partial}{\partial k} e^{i(kx-\omega t)} = x e^{i(kx-\omega t)}$
So why does this look like the momentum representation of the position operator (except for the sign)?
I was just wondering since I never learned the "explicit form" of the position operator. I just learned what it does, namely:
But my question is, what does $\hat{x} = \cdots$ look like specifically? Does the explicit form of $\hat{x} = \cdots$ depend on the function I'm using it on?
DanielC
  • 4,497
  • 25
  • 39
Let us first clarify that things like $\hat{x}\,\psi(x)$ in fact mean
$$ (\hat{x}\psi)(x) \equiv \langle x| \hat{x} |\psi\rangle \quad .$$ We further define the wave function as $$ \psi(x) \equiv \langle x|\psi\rangle \quad. $$
Similar equations hold for the case of the momentum operator / basis. In the following we set $\hbar=1$.
The position representation of the position and momentum operator is (very nicely explained here):
\begin{align} \langle x|\hat{x} &= \langle x| \,x \\ \langle x| \hat{p} &= - i \,\frac{\mathrm{d}}{\mathrm{d}x} \langle x| \quad . \end{align} This should look familiar to you: Evaluated in the position basis, the position operator acts as a multiplicative operator while the momentum operator acts as a derivative. Using the conventions from the beginning we then find \begin{align} (\hat{x}\psi)(x) &= x\, \psi(x) \\ (\hat{p}\psi)(x) &= - i \,\frac{\mathrm{d}}{\mathrm{d}x} \psi(x) \quad , \end{align}
which means for example that the projection of the vector $\hat{x}|\psi\rangle$ onto a state of the position basis is the number $ x\, \psi(x)$.
However, this does not mean that the momentum operator is a derivative; in the same sense, the position operator is not an operator multiplying 'everything' it acts on with $x$. Indeed, evaluated in the momentum basis, we find that the momentum operator is multiplicative and the position operator acts as a derivative: \begin{align} \langle p | \hat{x} &= i\, \frac{\mathrm{d}}{\mathrm{d}p} \langle p|\\ \langle p | \hat{p } &= \langle p |\,p \quad . \end{align} See also this question and the links therein. This tells us that e.g. the projection of the vector $\hat{x}|\psi\rangle$ onto an element of the momentum basis is the number $i\, \frac{\mathrm{d}}{\mathrm{d}p} \psi(p)$.
Finally, by making use of the completeness relations $\displaystyle \mathbb I = \int \mathrm dx \, |x\rangle \langle x| = \int \mathrm dp \, |p\rangle\langle p|$, we can express the action of the position operator $\hat{x}$ on a state $|\psi\rangle$ either as $$ \hat{x}|\psi\rangle = \int \mathrm{d}x\, x\, |x\rangle \langle x|\psi\rangle$$ or $$\hat{x}|\psi\rangle = i\,\int \mathrm{d}p \, |p\rangle \frac{\mathrm{d}}{\mathrm{d}p}\langle p|\psi\rangle \quad .$$
Regarding your example: We know that $\langle x |p\rangle = e^{ipx}$ (up to some constant factor which I'll omit) and let's say we want to calculate $ \langle x |\hat{x}|p\rangle$, which is I think you meant by $\hat{x}\, e^{ipx}$.
Using the position representation of the position operator, we easily find $$\langle x |\hat{x}|p\rangle = x \, \langle x|p\rangle = x \,e^{ipx} \quad . $$
Performing the calculation within the momentum representation of the position operator yields:
$$\langle x |\hat{x}|p\rangle = \left({\langle p |\hat{x}^\dagger|x\rangle }\right)^* = \left({\langle p |\hat{x}|x\rangle }\right)^* = \left(i \frac{\mathrm{d}}{\mathrm{d}p} e^{-ipx}\right)^* = x \, e^{ipx} \quad ,$$ as expected.
