13
My book about quantum mechanics states that the hamiltonian, defined as $$H=i\hbar\frac{\partial}{\partial t}$$ is a hermitian operator. But i don't really see how I have to interpret this. First of all: from which to which space is this operator working? They are defining a vectorspace called the "wavefunctionspace $F$" which contains all square-integrable functions that are continious and infinite differentiable (and everywhere defined). But it looks to me, that if the hamiltonian acts on this space, it's not necessary true that the image of a random vector of $F$ is again in $F$.
I think in fact, that there are some vectors of $F$ so that the hamiltonian of those vectors is not an element of $F$ (so that it's not an endomorphism on $F$). And if the hamiltonian has to be hermitian, it has to be an endomorphism on some space.
If we define instead the vectorspace $V$, which is the same space as $F$ but where functions don't have to be square-integrable, the hamiltonian will be an endomorphism (so at first I thought this was the solution). But now the inner product on functions $$<f,g> = \int_{-\infty}^\infty dx~{f^*g}$$ which was defined well on $F$ because the integral will always exist if $f$ and $g$ are function of $F$, is no longer properly defined.
I hope someone can clarify how I have to interpet this operator (the same question holds in fact for some other operators).
yarnamc
  • 1,281
The general situation is the following one. There is a self-adjoint operator $H :D(H) \to \cal H$, with $D(H) \subset \cal H$ a dense linear subspace of the Hilbert space $\cal H$. (An elementary case is ${\cal H} = L^2(\mathbb R, dx)$, but what follows is valid in general for every complex Hilbert space $\cal H$ associated to a quantum physical system.)
It turns out that $D(H) = \cal H$ if and only if $H$ is bounded (it happens, in particular, when $\cal H$ is finite dimensional).
Physically speaking $H$ is bounded if and only if the values the corresponding observable (the energy of the system) attain form a bounded set, so it hardly happens in concrete physical cases. $D(H)$ is almost always a proper subset of $\cal H$.
If $\psi \in \cal H$ represents a (pure) state of the system, its time evolution is given by $$\psi_t = e^{-i \frac{t}{\hbar} H}\psi \tag{1}\:.$$ The exponential is defined via spectral theorem. The map $\mathbb R \ni t \mapsto e^{-i \frac{t}{\hbar} H}\psi$ is always continuous referring to the topology of $\cal H$. Moreover it is also differentiable if and only if $\psi_t \in D(H)$ (it is equivalent to say that $\psi \in D(H)$). In this case one proves that (Stone theorem) $$\frac{d\psi_t}{dt} = -i \frac{1}{\hbar} H e^{-i \frac{t}{\hbar} H}\psi= -\frac{i}{\hbar} H\psi_t\:.$$ In other words, $$i \hbar \frac{d\psi_t}{dt} = H\psi_t\:.\tag{2}$$ It should be clear that $\frac{d}{dt}$ is not an operator on $\cal H$, as it acts on curves $\mathbb R \ni t \mapsto\psi_t$ instead of vectors. $$\frac{d\psi_t}{dt} = \lim_{s \to 0} \frac{1}{s} \left(\psi_{t+s}-\psi_t \right)$$ and the limit is computed with respect to the Hilbert space norm. Identity (2) holds if and only if $\psi \in D(H)$ and not in general.
ADDENDUM.
Identities or even definitions (!) like $$H = i \hbar \frac{d}{dt}\:.\tag{3}$$ make no sense. An observable in QM first of all is an operator (self-adjoint) on the Hilbert space $\cal H$ of the theory. In other words it is a linear map $A$ associating any given vector $\psi \in \cal H$ (or some suitable domain) to another vector $A\psi$. If $\psi$ is a given single vector of $\cal H$ - and not a curve $t \mapsto \psi_t$ - the formal object $$\frac{d}{dt}\psi$$ has no meaning at all as it cannot be computed! Thus, wondering whether or not $H$, "defined" by means of (3), is Hermitian does not make sense in turn, because the RHS of (3) is not an operator in $\cal H$.
The concrete definition of $H$ can be given as soon as the physical system is known and taking advantage of some further physical principles like some supposed correspondence between classical observables and quantum ones, or group theoretical assumptions about the symmetries of the system.
For non-relativistic elementary systems described in $L^2(\mathbb R^3)$, the Hamiltonian operator has the form of the (hopefully unique) self-adjoint extension of the symmetric operator $$H := -\frac{\hbar^2}{2m}\Delta + V(\vec{x})$$ That is the definition of $H$.
Nevertheless, Schroedinger equation (2) is always valid, no matter the specific features of the quantum (even relativistic) system, when $\psi \in D(H)$. Time evolution is however always described by (1) regardless any domain problem.
If the hamiltonian is hermitian, the eigenfunction make a base of the space of squared integrable function. So the action of H on any function stays on the squared integrable function space.
Jim
  • 24,676
sidi
You may be able to find some pathological examples for why operators in quantum mechanics aren't hermitian, but these aren't physical. This is physics, there is bound to be some sketchiness to the math. You might be interested in reading this for some interesting mathematical problems/surprises with the mathematical formulation of quantum mechanics: http://lanl.arxiv.org/pdf/quant-ph/9907069v2.pdf
JLA
  • 1,747
  • 17
  • 32
-3
As you said, the Equation you give works only in "wavefunctionspace". As long as you deal with wave functions, you can always decompose the object your derivative acts on as $$\int \frac{\mathrm d\omega }{\sqrt{2\pi}} \tilde f(\omega) e^{i \omega t}$$ so your derivative will draw a factor of $i \omega$ from the exponential. The general shape still is a superposition of plane waves and therefore still in $\mathbf F$, and the operator $i\hbar\frac{\mathrm d}{\mathrm dt}$ is self-adjoint.
Neuneck
  • 9,238
