Can a wave function be anything? such as a parabola. I know it is used to measure the probability of where a particle is (or so i think) in a 1 dimensional plane.
What is an example of a wave function that can be graphed?
Free wavefunctions (corresponding to a free particle) have to be continuous and smooth (the derivative has to exist everywhere, so, for example, no saw form function is allowed), and if you integrate the square of the function all over space this must result in the value 1: it's certain that you find the particle connected to the wavefunction somewhere in space, i.e., the probability is 1. We say that the wavefunction is normalized. An example of such a wavefunction (which can be plotted in a one-dimensional graph):
In general (when the particle is not free), the wavefunction must be continuous and square-integrable only. As is said in the comment below by @J.Murray.
Deschele Schilder
  • 45
  • 105
The wave function $\psi(x,t)$ for a specific time $t=t_0$ can be almost anything. $\psi(x,t_0)$ represents the initial condition of the quantum mechanical system. However, the squared magnitude $\psi^*\psi$ of the wave function also needs to be integrable (normalizable) over space, otherwise you cannot interpret it as a probability density (which must add up to one). That is why a parabola defined all over space cannot be a valid wave function, because a parabola is not normalizable. But, of course, the wave function could be a parabola on a finite domain if it drops off sufficiently fast outside that domain. In this case it would be normalizable again.
Due to the Schrödinger equation, the wave function at a different time $t=t_1$ is not arbitrary anymore, but given by the time evolution operator acting on the initial state: $$\psi(x,t)=\exp\left(-{\frac{i}{\hbar}H\cdot (t-t_0)}\right)\psi(x,t_0)$$ Don't be put off by the operator exponential, it is basically just a mathematical shorthand notation for "solving the Schrödinger equation".
You have to distinguish carefully between the above meaning of the wave function as the momentary state of the system and the eigen-states of the time-independent Schrödinger equation. The latter just serve as a very convenient basis for representing actual wave functions. The system need never be in any of the possible eigen-states, although it can be shown, that when considering radiation, the eigen-states are particularly stable, and hence, tend to be assumed asymptotically by the system.
Think of the Schrödinger equation as analogous to the wave equations that describe a drumhead. The drumhead can assume any shape (including initial velocities) you like at a given instant in time. But from there the further movement of the membrane is determined (at least until you hit the drum externally). The drumhead also has certain eigen-frequencies and corresponding eigen-shapes, which you may be able to excite selectively by carefully poking it with the drum stick at very specific locations. These are the analogs of the solutions to the time-independent Schrödinger equation. Any real excitation results in a superposition of the eigen-states combined with their respective time evolution (eigen-frequencies).
The crucial difference between the drum and a quantum mechanical system, however, is that for the drum you need to specify initial displacements and velocities, while the quantum mechanical wave function only needs to specify the initial state. This is a consequence of the Schrödinger equation being first order in the time-derivative, while the wave equation of the drumhead is second order in time.
oliver
  • 7,624
