Blackbodies emit a continuous spectrum of radiation, whereas a cavity with reflective walls at thermal equilibrium contains a discrete spectrum.
According to Kirchoff, "smoothing out" the spectrum of the cavity radiation by looking at the average number of frequencies permitted by the cavity in a small frequency interval from $f$ to $f+df$, which leads to the Rayleigh-Jeans law which was later refined and became Planck's law, should give the blackbody radiation spectrum.
Kirchoff's argument was that when the cavity is at thermal equilibrium at some temperature, for which another blackbody at this temperature must have been placed in it for some time before being removed, allowing a certain frequency band to escape from this cavity into another cavity with opaque, say, perfectly absorbing walls at the same temperature should not lead to a change in temperature of the walls of the cavity with opaque walls for this would violate the 2nd law of thermodynamics.
This sounds very convincing but I cannot help but contemplate the following:
If said frequency band that can pass through the filter is constrained to, say, the lowest frequency that is permitted by the cavity and we make this frequency band ever tighter around precisely this lowest permitted frequency. The amount of radiation that the walls of the opaque cavity can radiate into the cavity with reflective walls grows ever smaller since the opaque walls emit a continuous spectrum. The radiation the goes from the reflective cavity into the opaque cavity, however, will not change because our frequency band is constrained to this frequency which the cavity permits discretely. The walls in the opaque cavity would absorb more than they can radiate away and so their temperature rises and the 2nd law of thermodynamics would be violated.
Please share your insights as to why this is an incorrect analysis.
Quanta
  • 661
Planck’s law states that emission of light is
$$ I_\nu(\hbar\omega) = g(\hbar\omega) f(\hbar\omega, T) $$
Let’s say that $I_\nu$ is the energy emitted from the surface of the blackbody per unit area per into per unit solid angle per unit time.
If the blackbody is emitting into free empty space we know that the density of photon states is,
$$ g(\hbar\omega) = \frac{2\pi}{c^2h^3} \left(\hbar\omega\right)^2 $$
And because photons are bosons $f(\hbar\omega, T)$ is the Bose-Einstein distribution.
So two blackbody cavities radiating into free space will eventually come into equilibrium with each other by exchanging blackbody radiation over all wavelengths,
cavities in free space
If you now place a filter between the cavities which only passes energy at a single photon frequency.
cavities with filter
This does not change anything fundamental because they can still exchange energy and will eventually reach the same temperature.
It’s just like modifying the density of states with a delta function,
$$ I_\nu(\hbar\omega) = \delta(\hbar\omega_f)g(\hbar\omega) f(\hbar\omega, T) $$
boyfarrell
  • 3,329
First, some experimental facts from observation. If you look thru a small hole into a cavity at temperature T, you will see the continuous Planck spectrum as given by his formula. 1) You will not see any variations due to modes of the cavity. 2) The emissivity of the cavity walls also makes no difference. The material on the walls (soot. silver, copper, wood, or cotton candy) makes no difference to the Planck spectrum seen. How can this be?
  1. The frequency density of resonant modes of the cavity were used in the derivation of the Planck spectrum. But no cavity has zero resistivity walls. For walls with some resistivity, standing waves of any frequency can meet the boundary conditions. The tails of these "non-resonant" waves extend into the walls, and quickly dissipate their energy in the walls' resistance. Lasting perhaps for only one oscillation, these waves have a very low Q compared to the resonant modes. Let's now consider the standing wave to be the sum of the reflections of a plane wave bouncing back and forth between opposite walls. For non-resonant frequencies, this photon perhaps makes 1 trip across the cavity before being absorbed. For a resonant frequency, the photon makes 1000 trips across the cavity before being absorbed. However, because emissivity=absorptivity, the thermally excited oscillators in the walls are emitting 1000 times more photons/sec for the non-resonant versus resonant frequency! If we now look at a volume in the middle of the cavity, we see the same average density of photons from 1000 photons x 1 trip or 1 photon x 1000 trips. The modes of the cavity make no difference in the photon number density at different frequencies.
  2. We could again use the bounce back and forth argument with Kirchoff's emissivity=absorptivity, but let's do his thermodynamic argument. Two cavities, made of different materials, are connected by a small hole with a filter that passes frequency $\nu \pm \Delta \nu$. The two cavities have both come to the temperature T. The power passing the filter in both directions must be the same or we could use the unbalanced flow of energy to do work. This would violate the second law of thermodynamics by getting useable work from two heat baths at the same temperature. Kirchoff concluded there was a universal spectrum, independent of cavity material, that emerged from all cavities, though it was left to Planck to deduce the actual function. You can also conclude that the cavities can't show any peaks due to modes. Otherwise, the filter could be set to pass a peak from the first cavity that the second cavity did not have. Power would again pass from a cavity at temperature T and warm a cavity of the same temperature T, violating the second law.
So, the resolution of the op's original question is that the black body spectrum in cavities is universal, and does not show modes. This is not to say cavity modes can't be excited by an antenna in the cavity broadcasting power from a sine wave generator. Also, the black body spectrum from a radiator, not in thermal equilibrium with its $4\pi$ surrounds, is modified by the emissivity of its material.
Gary Godfrey
  • 3,428
I think you argument and conclusion are correct. A cavity which radiates only at discrete frequencies won't behave as blackbody radiator and will put out more energy than it receives at those discrete frequencies.
It is the assumption that is wrong - the idea that perfectly reflecting cavity with equilibrium radiation radiates at discrete frequencies. Equilibrium radiation means all frequencies are possible, not just some discrete ones.
The idea there are only waves of discrete frequencies inside the cavity probably comes from the usual derivation on Rayleigh-Jeans or Planck's formula, where the field is expanded into Fourier series.
Fourier series has the property that in expressing the function of position $x$, only sine waves with integer multiples of a fundamental wave number $\frac{\pi}{L}$ are present, where $L$ is size of the region where we seek to express the function as Fourier series. This region is usually taken to be the whole inside of the cavity, but nothing prevents us from taking a bigger box with side length $2L$.
With twice as big integrating region dimensions, we get twice as dense wave numbers and twice as dense corresponding frequencies $\omega_{nlm} = \frac{\pi c\sqrt{n^2+l^2+m^2} }{2L}$. Instead of a fundamental frequency (lowest) at $\frac{\pi c\sqrt{3}}{L}$ we get fundamental frequency at $\frac{\pi c\sqrt{3}}{2L}$, which is lower. Behold, radiation at lower frequency appeared, just due to using a different integrating region!
It is clear that position of singularities and their strengths are an artifact of the particular finite integrating region in the Fourier series method. They are correct for the used region, but there are infinitely many other choices.
If we use Fourier integral expansion instead of the Fourier series expansion, there is no $L$ in the formulae, and no discreteness in Fourier amplitude $\tilde{E}_x(k,l,m)$ as function of continuous wavenumbers $k,l,m$. It all becomes unique continuous quantities.
So equilibrium radiation inside a perfectly reflecting cavity is not (except near the cavity walls) physically different from that of a bigger cavity or radiation of a cavity that has walls made of blackbody at the same temperature.
