The question is:
The angular momentum components of an atom prepared in the state $|\psi\rangle$ are measured and the following experimental probabilities are obtained: \begin{equation} P(+\hat{z}) = 1/2, P(−\hat{z}) = 1/2, \end{equation} \begin{equation} P(\hat{x}) = 3/4, P(−\hat{x}) = 1/4, \end{equation} \begin{equation} P(+\hat{y}) = 0.067, P(−\hat{y}) = 0.933. \end{equation} From this experimental data, determine the state $|\psi \rangle$. Note that in performing the measurements, the state $|\psi \rangle$ is prepared again and again.
My attempt: $$ P(+\hat{z}) = 1/2 = P(−\hat{z}) $$ $$ |\langle {\uparrow}_z|\psi\rangle|^2=1/2 =|\langle {\downarrow}_z|\psi\rangle|^2 $$ $$ |\psi \rangle =\alpha |{\uparrow}_z\rangle+ e^{iδb} \beta|{\downarrow}_z\rangle $$ $$ |\langle {\uparrow}_z|\psi\rangle|= \alpha = 1/\sqrt(2). $$ Similarly, $$ |\langle {\downarrow}_z|\psi\rangle|= \beta = 1/\sqrt(2). $$
However, I don't know how to find $e^{iδb}$ term. Could someone please give a hint?
VoulKons
  • 16,825
  • 45
  • 73
rand1
  • 189
REFERENCE : My answer here Understanding the Bloch sphere
Equation (24) in my answer above is
\begin{equation} \vert\psi\rangle \boldsymbol{=}\cos\left(\dfrac{\theta_3}{2}\right)\vert u_3\rangle \boldsymbol{+} e^{i\phi_3}\sin\left(\dfrac{\theta_3}{2}\right)\vert d_3\rangle \tag{24}\label{24} \end{equation} where $\vert u_3\rangle ,\vert d_3\rangle $ are yours $|{\uparrow}_z\rangle,|{\downarrow}_z\rangle$ respectively.
From the given probabilities $P(+\hat{z}) = 1/2, P(−\hat{z}) = 1/2 $ the state lies on the "equator" of the Bloch sphere. So from Figure-01 in my REFERENCED answer $\theta_3=\pi/2$. The angle $\phi_3=\boldsymbol{-}\pi/3$ could be found from one only of the probabilities $P(\hat{x}) = 3/4, P(−\hat{x}) = 1/4,P(+\hat{y}) = 0.067$, $P(−\hat{y}) = 0.933$ and Figure-02 in my REFERENCED answer.
Note : I suggest you to "study" the excellent @CR Drost's answer about the Bloch sphere in above link.
See a 3d view of Figure-03 here
VoulKons
  • 16,825
  • 45
  • 73
