When reading about Superficial Degrees of Divergence (SDOD) I have seen in An Introduction to Field Theory (Chapter 10.1) that for Lagrangians with a $\phi^n$ interaction term we know that:
$$\tag{1} L=P -V +1,$$ $$\tag{2} nV = N + 2P,$$
Where $L$ represents the number of loops in a diagram, $P$ the number of internal propagators, $N$ the number of external lines and $V$ the number of vertices.
The degree of divergence of the diagram is given by:
$$\tag{3}D=dL-2P.$$
Why is this so? Is there a way to derive these equations though calculations or is it just a known fact?
user7077252
  • 769
  • 24
  1. OP's eq. (1) is explained around eq. (8) of my Phys.SE answer here.
  2. OP's eq. (2) essentially follows from a counting argument: Each external (internal) propagator connects 1 (2) end(s) to the vertices, respectively: $$ 1\times N + 2\times P~=~\sum_{n}nV_n~=~3V_3+4V_4+5V_5+\ldots. \tag{2}$$
  3. For a connected Feynman diagram the superficial degree of (UV) divergence $D$ is defined as $$ D~:=~ \#\{\text{$\mathrm{d}p$ in int. measure}\} ~+~ \#\{\text{$p$ in numerator}\}~-~ \#\{\text{$p$ in denominator}\}. \tag{3}$$ The 1st term on the RHS is $Ld$. The 2nd term on the RHS is 0 if there are no derivative couplings. In OP case, the 3rd term on the RHS carries a loop momentum power $-2$ for each of $P$ internal scalar propagators. This leads to OP's eq. (3). A generalization of eq. (3) is given in my Phys.SE answer here.
if you have something like this : $$\sim \int \dfrac{d^4 k_1 d^4 k_2 \dots d^4 k_L}{(\bar{k}_i-m) \dots k^2_j \dots }$$ that for each propagator you have power of 2 of momentum in denominator and for each loop you have power of $d-1$ of momentum for measure of integral in numerator that after integrating become $d$.so for degree of divergence you should calculate(Show that with ND) :
$ND = (power\ of\ $k$\ in\ numerator - power\ of\ $k$\ in\ denominator)$.(after integrating that plus 1 to measure of numerator)
because we have $L$ measures that should be integrating, for power of $k$ in numerator we have $dL$(after integrating) , and because we have $P$ propagator each have power of $2$ in denominator so power of $k$ in denominator should be $2P$. so final result for degree of divergence is $dL-2P$.
a.p
  • 245
