I now agree with @Farcher answer, though it was (and still is) counter-intuitive to me. I am more conversant in statics and mechanics of materials then dynamics. In statics you can move a couple and it has no effect on the requirements for static equilibrium. But in mechanics of materials, where you evaluate the magnitude and location of shear and bending stresses, you cannot move the couple. That appears not to apply in the case of dynamics of rigid bodies.
You might consider the following as a way of proving that you can move the couple anywhere on the object without changing the moment about any point on the object:
What is the sum of the moments about the point exactly in between the two forces? It is 5 x 1500 = 7500 Nm clockwise.
Now take the sum of the moments about the center of mass. It is also 5 x 1500 = 7500 Nm clockwise.
In fact, if you take the sum of the moments about ANY point on the object, you will always get 7500 Nm clockwise. This shows to me that, for dynamics, the couple can be moved anywhere.
Hope this helps.
