Good question. The textbook formalism in Quantum Mechanics & QFT just doesn't deal with this problem (as well as a few others). It deals with cases where there is a well-defined moment of measurement, and a variable with a corresponding hermitian operator $x, p, H$, etc is measured. However there are questions which can be asked, like this one, which stray outside of that structure.
Here is a physical answer to your question in the framework of QM: Look at the a position wave function of the decayed particle $\psi(x)$ (*if it exists: see bottom of post if you care). When this wave function "reaches the detector" (though it probably has some nonzero value in the detector the entire time) the Geiger counter registers a decay. Using this you get a characteristic decay time. This picture is a good intuition, but also an inexact/insufficient answer, because the notion of "reaches the detector" is only heuristic and classical. A full quantum treatment of this problem should give us more: a probability distribution in time $\rho(t)$ for when the particle is detected. I will come back to this.
So what about the Zeno effect? Based on the reasoning you gave, the chance of decaying is always zero, which is obviously a problem! Translating your question to position space $\psi(x)$, your reasoning says the wave function should be projected to $0$ in the region of the detector at every moment in time that the particle hasn't been found. And in fact you're right - doing this does cause the wave function to never arrive at the detector! (I actually just modeled this as part of my thesis). This result is inconsistent with experiment, so we can conclude: continuously-looking measurement cannot be modeled by straightforward projection inside the detector at every instant in time.
A note, in response to the comments of Mark Mitchison and JPattarini: this "constant projection" model of a continuous measurement can be modified by choosing a nonzero time between measurements $\Delta t \neq 0$. Such models can give a discrete distribution, and $\Delta t$ can be chosen based on a characteristic detector time, but in my view such models are only heuristic and a deeper, more precise explanation is needed. Mark Mitchison gave helpful replies and linked sources in the comments for anyone who wants to read more on this. Another way to rescue the model is to redefine the projections to be "softer", as in the sources linked by JPattarini.
Anyway, despite the above discussion, there is still a gaping question: If continuous projection of the wave function is wrong, what is the correct way to model this experiment? As a reminder, we want to find a probability density function of time, $\rho(t)$, so that $\int_{t_a}^{t_b}\rho(t)dt$ is the probability that the particle was detected in time interval $(t_a, t_b)$. The textbook way to find a probability distribution for an observable is to use the eigenstates of the corresponding operator ($|x\rangle$ for position, $|p\rangle$ for momentum, etc) to form probability densities like $|\langle x | \psi \rangle|^2$. But there is no clear self-adjoint "time operator", so textbook quantum mechanics doesn't give an answer.
One non-textbook way to derive such a $\rho(t)$ is the "finite $\Delta t$ approach" mentioned in the note above, but besides this there are a variety of other methods which give reasonable results. The issue is, they don't all give the same results (at least not in all regimes)! The theory doesn't have a definitive answer on how to find such a $\rho(t)$ in general; this is actually an open question. Predicting "when" something happens in Quantum Mechanics (or the probability density for when it happens) is a weak point of the theory, which needs work. If you don't want to take my word for it, take a look at Gonzalo Muga's textbook Time in Quantum Mechanics which is a good summary of different approaches on time problems in QM which are still open to be solved today in a completely satisfactory way. I am still learning more about these approaches, but if you are curious, the one I found most clean so far uses trajectories in Bohmian Mechanics to define when the particle arrives at the detector. That said, the measurement framework in QM in general is just imprecise, and I would be very happy if a new way of understanding measurement were found which gives a higher level of understanding of questions like this one. (yes I am aware of decoherence arguments, but even they leave questions like this unanswered, and even Wojciech Zurek, the pioneer of decoherence, does not argue that it fully solves problems with measurement)
(*note from 2nd paragraph): Sure you can in principle hope to position representation to get a characteristic decay time like this, but it might not be as easy as it sounds because QFT has issues with position space wave functions, and you'd need QFT to describe annihilation/creation of particles. Thus even this intuition doesn't always have mathematical backing.
