In the derivation of Fermi's golden rule one typically arrives at an expression of the form $$ \frac{\sin^2(\omega t)}{\omega^2} $$ which is then converted to $$ \pi t\delta(\omega). $$ I cannot follow this step. I know the following identity $$ \delta (\omega) = \lim_{t\rightarrow \infty}\frac{\sin^2(\omega t)}{\pi |t|\omega^2} $$ from which i would assume that one extends the first expression by $\frac{t}{t}$ and then does the limit. But how can you pull the $t$ out of the limit ? Is this rigorous or is this an approximation ?
I think it should be like this $$ \lim_{t\rightarrow\infty} \frac{t}{t}\frac{\sin^2(\omega t)}{\omega^2} \not = \pi t\delta(\omega) $$ and the equation should be $$ \lim_{t\rightarrow\infty} \frac{t}{t}\frac{\sin^2(\omega t)}{\omega^2} = \pi \delta(\omega) \lim_{t\rightarrow \infty}t. $$ Am i wrong in the above equations ? Otherwise i don't see how Fermi's goldene rule could ever work since we assume at one time that $t$ is so large that we can approximate a function in the limit that $t$ goes to infinity while on the other hand $t$ has to be small such that pertubation theory of first order is accurate. These conditions seem to contradict each other but in every book i find this step. I haven't found any satisfactory answer so far regarding this step. I know the general conditins for pertubation theory but i find the form with the dirac delta function nonsensical. I assume that i go wrong at some point since no one ever brings this point up, please point out my error if i did something wrong.
