Consider a quantum square potential well with infinite depth: $$ V(x)=\begin{cases} 0, &|x|<a \\ +\infty, &\text{otherwise}. \end{cases}$$ Solving the Schodinger equation of a particle with mass $m$ in it gives the energy levels $$ E_n=\frac{n^2}{8m}\left(\frac{\hbar \pi}{a}\right)^2. $$ You can see that the energies are not equally spaced.
Now consider a string with both ends fixed. Standing waves on the string can vibrate at frequencies $nf$ only, where $f$ is the fundamental frequency, and $n$ is a positive integer. This time the "energy levels" ($\propto$ frequency) is equally spaced.
(We also get equally spaced energy levels in quantum harmonic oscillators.)
The similarity of the two situations above is that the value of a quantity (such as energy) has to be on discrete "levels" (cannot change continuously) due to the boundary conditions. However, the "levels" produced are not exactly the same: one of them $\propto n^2$, the other $\propto n$.
Questions:
- What difference between the Schrodinger equation for a potential well and the wave equation for a string is responsible for the difference in the spacing of energy levels? Intuitively, both equations are describing waves, so why one produce levels $\propto n^2$ while the other produce levels $\propto n$? What's really different?
- Is there a system in classical mechanics that behave very similar to the quantum potential well? I want to find a classical system that also has levels of $\propto n^2$?
