I have read this question:
Does photon interference violate causality?
where S.Mcgrew says:
Edit 8/10/18 Bottom line: you're right that wave function collapse violates the principle of causality. The term "measurement problem" encompasses that issue. This article discusses the measurement problem, but does not provide clear explanations. This paper: dives into the philosophical aspects of various approaches to resolving the measurement problem, but is a difficult read. The frustration of trying to come up with an intuitively satisfying interpretation has led to the "stop worrying about it and just do the math" approach to quantum mechanics -- which works, but doesn't fulfill our desire to understand what the math means. End edit
How does electron spin change instantaneously without violating inertia principle?
where Jasper says:
Most importantly, it is important to realize that instantaneous is meaningless in QM, since this can never be accurately determined. To determine a change in a system requires two measurements, which themselves take time to complete. In this way it is impossible to say when things "exactly" occurred. That being said, in QM you can determine the time-scale over which the dynamics occurs.
Now causality is where a process (cause) that contributes to another process, an effect. Causes all lie in the past, and effects in the future.
https://en.wikipedia.org/wiki/Causality
Now I suppose that wavefunction collapse is when a wave function (in a superposition), appears to reduce to a single eigenstate, due to interaction with the external world (observation).
https://en.wikipedia.org/wiki/Wave_function_collapse
Now I have not found why wave function collapse (that is, apparent reduction to a single eigenstate) would violate causality.
Question:
  1. Why does wave function collapse violate causality?
Collapse of wave function (if real) does not violate causality (cause and effect relationship) in its most basic form. But it does violate the speed limit of transmission of the effect of the cause. This speed limit is c and is set in theory of relativity.
If causality in its basic form is violated, that will be end of experimental science. Because, then we can not rely on any scientific experiment. All scientific experiments are - if you do this, then that will happen. Meaning all experimental science is based upon causality.
Collapse of wave function puts speed of causality into question, not causality itself.
kpv
  • 4,529
