12
I am trying to proof explicitly that Schrodinger equation: $$ i\hbar \partial_t \psi = \left[ -\frac{1}{2m}\left(\frac{\hbar}{i}\nabla-q\vec{A}\right)^2+qV \right]\psi$$
remains the same under the following gauge transformation:
$$ \psi \rightarrow e^{iq\Lambda/\hbar} \psi$$ $$ \vec{A} \rightarrow \vec{A} + \nabla \Lambda$$ $$ V \rightarrow V - \partial_t\Lambda$$
where $\partial_t$ stands for the time derivative operator.
However, I am having problems with the algebra, so I will show my procedure with the hopes that someone point to an error:
Left side of equation $$ i\hbar \partial_t (e^{iq\Lambda/\hbar}\psi) = ih \left(e^{iq\Lambda/\hbar} \partial_t\psi+\frac{iq}{\hbar}e^{iq\Lambda/\hbar} \psi \partial_t\Lambda \right) = ihe^{iq\Lambda/\hbar} \partial_t\psi-qe^{iq\Lambda/\hbar} \psi \partial_t\Lambda $$
Right side of equation $$ \left[ \frac{1}{2m}\left(\frac{\hbar}{i}\nabla-q(\vec{A} + \nabla \Lambda)\right)^2+q(V - \partial_t\Lambda) \right]= $$ $$ \frac{1}{2m} \left[ -\hbar^2\nabla^2-\frac{q\hbar}{i}( \nabla \cdot\vec{A} + \nabla^2\Lambda+ \vec{A} \cdot \nabla + \nabla \Lambda \cdot \nabla) + q^2[\vec{A}^2+2(\vec{A}\cdot \nabla \Lambda) + (\nabla \Lambda )^2]\right] e^{iq\Lambda/\hbar} \psi +qV e^{iq\Lambda/\hbar} \psi -qe^{iq\Lambda/\hbar} \psi \partial_t\Lambda $$
It is possible to observe that the last term in both (the right and left) sides cancel each other. Then, using:
$\nabla ( e^{iq\Lambda/\hbar} \psi ) = e^{iq\Lambda/\hbar}\nabla\psi + \frac{iq}{h} \psi \nabla \Lambda$
$ \nabla^2 ( e^{iq\Lambda/\hbar} \psi ) =e^{iq\Lambda/\hbar} \nabla^2\psi + \frac{2iq}{\hbar}e^{iq\Lambda/\hbar}(\nabla \Lambda)(\nabla \psi) + \psi \frac{iq}{\hbar} e^{iq\Lambda/\hbar} \nabla^2 \Lambda - \frac{q^2}{\hbar^2}\psi e^{iq\Lambda/\hbar} (\nabla \Lambda)^2 $
we then obtain (by applying operators and canceling all the $e^{iq\Lambda/\hbar}$ ):
$$ i\hbar \partial_t \psi= \frac{1}{2m} \left[ -\hbar^2 \nabla^2 \psi - 2iqh(\nabla \Lambda)(\nabla \psi)-iq\hbar \psi \nabla^2\Lambda + q^2\psi(\nabla \Lambda)^2 + iq\hbar (\nabla \cdot \vec{A})\psi + iq\hbar\nabla^2\Lambda \psi +iq\hbar (\vec{A}\cdot \nabla\psi) - q^2 \psi (\vec{A}\cdot \nabla \Lambda )+iq\hbar (\nabla \Lambda)(\nabla \psi) - q^2\psi (\nabla\Lambda)^2+q^2\vec{A}^2+2q^2(\vec{A}\cdot \nabla \Lambda)\psi +q^2(\nabla \Lambda)^2 \psi \right] + qV\psi$$
cancelling some terms, and rearranging:
$$ i\hbar \partial_t \psi= \frac{1}{2m} \left[ -\hbar^2 \nabla^2 \psi + iq\hbar (\nabla \cdot \vec{A})\psi +iq\hbar (\vec{A}\cdot \nabla\psi)+q^2\vec{A}^2 - 2iqh(\nabla \Lambda)(\nabla \psi) + q^2\psi(\nabla \Lambda)^2- q^2 \psi (\vec{A}\cdot \nabla \Lambda )+iq\hbar (\nabla \Lambda)(\nabla \psi) +2q^2(\vec{A}\cdot \nabla \Lambda)\psi \right] + qV\psi $$
after more reordering:
$$ i\hbar \partial_t \psi= \frac{1}{2m} \left[ \left(\frac{\hbar}{i}\nabla-q\vec{A}\right)^2 \right] +qV\psi + \frac{1}{2m} \left[ - iqh(\nabla \Lambda)(\nabla \psi) + q^2\psi(\nabla \Lambda)^2 + q^2(\vec{A}\cdot \nabla \Lambda)\psi \right]$$
It is possible to observe that the original schrodinger equation is up there, but with an extra part in the right side, this extra part is: $$ \frac{1}{2m} \left[ - iqh(\nabla \Lambda)(\nabla \psi) + q^2\psi(\nabla \Lambda)^2 + q^2(\vec{A}\cdot \nabla \Lambda)\psi \right]$$
So am wondering, is this extra part some how 0, or am I making a mistake. Also I don't know how to make the algebra "nicer" to follow, if there is anything I can do please comment.
Roger V.
  • 68,984
Ivan
  • 1,018
Actually, Schroedinger equation $$ -i\hbar \partial_t \psi+ \left[ -\frac{1}{2m}\left(\frac{\hbar}{i}\nabla-q\vec{A}\right)^2+qV \right]\psi=0\tag{0}$$ under the gauge transformations
$$ \psi \rightarrow \psi'= e^{iq\Lambda/\hbar} \psi$$ $$ \vec{A} \rightarrow \vec{A}' = \vec{A} + \nabla \Lambda$$ $$ V \rightarrow V'= V - \partial_t\Lambda$$
does not remain invariant, but the left-hand side of (0) gives rise to $$ -i\hbar \partial_t \psi'+ \left[ -\frac{1}{2m}\left(\frac{\hbar}{i}\nabla-q\vec{A}'\right)^2+qV' \right]\psi'= e^{iq\Lambda/\hbar}\left\{-i\hbar \partial_t \psi+ \left[ -\frac{1}{2m}\left(\frac{\hbar}{i}\nabla-q\vec{A}\right)^2+qV \right]\psi\right\}\:.$$
In summary, since $e^{iq\Lambda/\hbar}\neq 0$,
$\qquad\quad$ gauge transformed quantities satisfy Schroedinger equation if untranformed quantities do.
To prove it, avoid brute force computations as yours which give rise to unavoidable mistakes almost certainly and go on as follows. First rewrite the initial equation as $$ -\left[i\hbar \partial_t -qV \right]\psi -\frac{1}{2m}\left(\frac{\hbar}{i}\nabla-q\vec{A}\right)^2\psi=0\tag{1}$$ Next notice that, under the transformations, we have
$$\left[i\hbar \partial_t -qV' \right]\psi' = \left[i\hbar \partial_t -q(V - \partial_t\Lambda)\right]e^{iq\Lambda/\hbar}\psi = e^{iq\Lambda/\hbar}\left[i\hbar \partial_t -qV \right]\psi $$ and $$\left(\frac{\hbar}{i}\nabla-q\vec{A}'\right)\psi' = \left(\frac{\hbar}{i}\nabla-q(\vec{A} +\nabla \Lambda)\right)e^{iq\Lambda/\hbar}\psi = e^{iq\Lambda/\hbar}\left(\frac{\hbar}{i}\nabla-q\vec{A}\right)\psi$$ so that, iterating the second result $$\left(\frac{\hbar}{i}\nabla-q\vec{A}'\right)^2\psi' = e^{iq\Lambda/\hbar}\left(\frac{\hbar}{i}\nabla-q\vec{A}\right)^2\psi\:.$$ Putting all together, under the action of gauge transformations, (1) becomes $$ -\left[i\hbar \partial_t -qV' \right]\psi' -\frac{1}{2m}\left(\frac{\hbar}{i}\nabla-q\vec{A}'\right)^2\psi' = e^{iq\Lambda/\hbar}\left\{-\left[i\hbar \partial_t -qV \right]\psi -\frac{1}{2m}\left(\frac{\hbar}{i}\nabla-q\vec{A}\right)^2\psi\right\}=0$$ as wanted.
Roger V.
  • 68,984
Check this video by the great Barton Zwiebach from MIT lectures.
He does exactle what you are doing in a 20 min video, if the link stop working, it is Lecture L14.1 from the MIT course 8.06 Quantum Physics III, Spring 2018, which you will always find on Youtube or in the MIT lectures web.
Alternatively, one may use that:
  1. The Schrödinger Lagrangian density $${\cal L}~=~\frac{i\hbar}{2}\left(\psi^{\dagger}D_t\psi-(D_t\psi)^{\dagger}\psi \right)- \frac{\hbar^2}{2m}|\vec{D}\psi|^2$$ is gauge invariant, where the gauge covariant derivatives are $$\vec{D}~=~\vec{\nabla}-\frac{iq}{\hbar}\vec{A}, \qquad D_t~=~\partial_t-\frac{iq}{\hbar}A_t,\qquad A_t~\equiv~-V,$$ in the Minkowski$^1$ signature $(-,+,\ldots, +)$.
  2. Hence the corresponding Euler-Lagrange equation (=the TDSE) is gauge covariant, cf. e.g. this Phys.SE post and OP's title question.
$^1$ The choice of Minkowski signature is merely to connect to standard conventions; it is not fundamental.
