So I'm going through my notes and I think I've confused myself. We often imply $$ |\psi\rangle \to \psi(x)\\ \langle\psi| \to \psi(x)^* $$ for instance when we talk about eigenvalue equations we interpret $$ \hat{H}|\psi\rangle =E|\psi\rangle $$ as simply $$ \hat{H}\psi(x)=E\psi(x) $$ but I don't understand why we say $|\psi\rangle \to \psi(x)$ because if that was the case then $$ \langle\psi|\psi\rangle=|\psi|^2 $$ when clearly $$ \langle\psi|\psi\rangle=\int_{-\infty}^\infty |\psi|^2 dx = 1 $$ I'm obviously missing something simple, could anyone point out where I'm going wrong?
To start, the kets are vectors, which means if we want an explicit realization of them, we would need to write them with respect to some basis. The first basis most people see is the position basis, where the basis kets are the states of definite position. Then, an arbitrary state $|\psi\rangle$ can be written as
$$ |\psi\rangle = \int_{-\infty}^{\infty}dx \ \psi(x)|x\rangle,$$
where $\psi(x)$ is the familiar position space wavefunction. This should help explain why the last line has the integral in it, it comes from this superposition of states of definite position.
Now for rewriting $\hat{H}|\psi\rangle = E|\psi\rangle$, the exact same thing happens, but the reason there aren't any integrals is because the $\hat{H}$ in $\hat{H}\psi(x) = E\psi(x)$ is written as an differential operator acting on position space now, rather than an operator that acts in some way on an arbitrary ket. This might be a slight abuse of notation, but it is usually clear from context what basis the Hamiltonian is written in in a given equation.
- 1,084
The state of a quantum system is an element of a vector space (a Hilbert space, specifically). The notation $|\psi\rangle$ is used to label a particular vector in this space. Operators such as $\hat{H}$ map states in the Hilbert space to other states in the Hilbert space, so $\hat{H} |\psi\rangle = |\phi\rangle$, where $|\phi\rangle$ is another state in the Hilbert space. Some vectors might be eigenvectors of an operator, in which case we might write $\hat{H}|\psi\rangle = E |\psi\rangle$ (where $E$ is just a regular number, the eigenvalue).
If we are considering a wavefunction that describes the real-space motion of a particle, then we might be interested in the spread of the wavefunction over space. The Hilbert space in this case is infinite-dimensional. A natural choice for the basis vectors in which to expand $|\psi\rangle$ is the position eigenstates $|x\rangle$, where $x$ is any position in real space. $|\psi\rangle$ can always be expressed as a superposition of different basis states with different amplitudes in each basis state: $$ |\psi\rangle = \int dx \ \psi(x)|x\rangle $$ where $\psi(x)$ is now a function that maps positions to some complex amplitude.
We can formally relate $\psi(x)$ to $|\psi\rangle$ as follows: take the inner product of the expansion of $|\psi\rangle$ in the position basis with any particular position eigenstate $|x'\rangle$: $$ \langle x' | \psi \rangle = \int dx \ \psi(x) \langle x' | x \rangle = \psi(x') $$ where we rely on the fact that different position eigenstates are orthogonal (ie., $\langle x' | x \rangle = \delta(x-x')$).
So $\psi(x) = \langle x | \psi \rangle$. That is, the amplitude of the wavefunction at a position $x$ is given by the projection of the state $|\psi\rangle$ onto the basis state defined at position $x$, $|x\rangle$.
- 1,484
- 10
- 11
This is something that confuses many students learning about quantum mechanics. It is important to understand the concept of different 'spaces'. Physicists deal with many different spaces: the usual 3D real space we live in, and many other abstract 'spaces'.
The Hilbert space of a particle is the 'space' of all possible states the particle can be in. It is NOT the same 3D space that the particle actually 'moves around in'. The Hilbert space also obeys the usual laws of linear algebra, but it is infinite dimensional.
In particular, the dimensionality is equal to the number of points in space, and the set of basis vectors is $\{\,|x\rangle\,|\,x\in \mathbb{R}\}$. The meaning of $|x\rangle$ as a state is "the particle is located at x". $|x\rangle$ is also a basis vector of the Hilbert space; note that there is one for every $x$. So $|2.77\rangle$, $|\sqrt{3}\rangle$, $|\pi\rangle$, and $|42\rangle$ are all basis vectors, as are an infinite other ones.
The important equation is actually $\langle x|\psi\rangle = \psi(x)$. This is the 'proper' version of your $|\psi \rangle \rightarrow \psi(x)$. The vector $|\psi\rangle$ lives in Hilbert space and is the abstract mathematical object representing the state of the particle. The equation $\langle x|\psi\rangle = \psi(x)$ essentially says that the scalar product of $| x\rangle$ and $|\psi\rangle$, or, 'the component of the vector $|\psi\rangle$ along the $|x\rangle$ direction' is equal to some number which we call $\psi(x)$. Because of the infinite dimension, you can take all of these scalar products (i.e. all the components of $|\psi\rangle$ along all the possible 'directions') and piece them together into a continuous function, the wave function.
- 386
Technically speaking if $\vert \psi\rangle\to \psi(x)$ then $\langle\psi\vert\to \int \,dx\, \psi(x)^*$. The integral symbol guarantees that glueing a bra and a ket together, $\langle \phi \vert \psi\rangle$, is a scalar product and a (generally complex) number, gives the same as the number computed as $\int dx \phi^*(x)\psi(x)$.
More specifically, $\psi(x)$ is really $\langle x\vert\psi\rangle$, as per this question. Using $\langle x\vert\psi\rangle =\psi(x)$ allows to interpret $\psi(x)$ as the component of $\vert\psi\rangle$ along the basis vector $\vert x\rangle$. If you buy this then you can also express $\vert \psi\rangle$ in the momentum basis, where $\psi(p)=\langle p\vert\psi\rangle$.
There are even states - like spin states $\vert \pm\rangle$, for which there is no "spatial" wavefunction, i.e. $\langle x\vert +\rangle$ doesn't make sense as the spin degree of freedom does have physical dimensions.
The Dirac notation is thus a way of emphasizing the vectorial nature of states, which can be combined and multiplied by scalars just like vectors can. It also emphasizes that expressing $\psi(x)$ or $\psi(p)$, i.e. the wavefunction in position or momentum space, is basically a choice of basis, much like choosing to express a vector in spherical or Cartesian coordinates. Indeed, to go from one basis to the other we need the transition formula $\langle x\vert p\rangle \sim e^{-i p x/\hbar}$.
- 49,168
- 21
- 71
- 148
It's actually not the case that $\langle \psi | = \psi(x)^*$. A more accurate statement would be as follows.
$$\langle \psi |\cdots := \int_{-\infty}^\infty dx\ \psi(x)^*\cdots $$
This bra $\langle \psi |$ can thus be thought of as a function that maps ket states $| \phi \rangle$ to a complex number.
$$|\phi\rangle \overset{\langle \psi |}{\mapsto} \langle \psi |\phi \rangle := \int_{-\infty}^\infty dx\ \psi(x)^* \phi(x) \in \mathbb C$$
- 1,903
When the state space is the projectivized Hilbert space of $L^2$ functions on $ℝ^1$, $|\psi\rangle$ is by definition the name of the equivalence class represented by the function $\psi$. $\langle\phi|\psi\rangle$ is by definition the same thing as $\int|\phi(x)\psi(x)|$ (when the state space is the projectivized Hilbert space of $L^2$ functions on $ℝ^1$".).
- 18,387
