-2
$$ψ=e^{iκx}$$
Since the wave function is an exponential equation, is there no point with zero probability density of finding a given particle? Does that justify quantum tunneling?
I think you are confusing things a bit. What you have there is the one-dimensional wavefunction for a free particle (i.e. plane wave), stripped of its time dependence. Indeed, if you try to compute its probability distribution via $P(x)=|\psi (x)|^2=\psi (x) \psi^*(x)$ then you will get 1, meaning it is position independent - it is as likely to be found in a certain place as in any other place, as you’d expect from a free particle. In jargon, a particle represented by such a wave function is completely delocalised.
To have quantum tunnelling, by definition, your particle has to “tunnel” through some potential barrier. This means the potential cannot be zero everywhere, i.e. the wavefunction cannot be that of a plane wave. Hence why your question does not make sense; a particle represented by that wavefunction has, by definition, nothing (no barrier or step) to “tunnel” through.
Where I think your confusion arises is that the free-particle wavefunction can be valid for a certain range of positions. For example, you might say that the wavefunction is $e^{ikx}$ within, say, $|x|<d/2$, and $0$ otherwise (read it as a piecewise function). This, for example, is an infinite potential well centred at $x=0$ and of diameter $d$. In this case, the potential is zero inside the well, so you can use the free particle wavefunction here, provided you apply the boundary conditions. However, there is no quantum tunnelling in infinite potential wells (indeed, one of the boundary conditions is that the wavefunction be zero at the boundaries). You start seeing quantum tunnelling, in the form of a decaying exponential in classically forbidden regions, when you start evaluating finite square wells, or potential steps/barriers.
capo
  • 430
-2
I believe this a great and fundamental question.
There are no infinite potential walls in the universe.
Quantum mechanics says the probability for any particle to be in any finite amount of space is always greater zero. Yes, this is the mathematical foundation of tunneling (except that, as has already been remarked, your mathematical model expression is missing a possibility to move in time).
PS: If you care to vote down my answer, please take a moment and share your thoughts in the comments. Thank you :)
Sol Hator
