Why is a compressed air tank cold to the touch when it’s in a compressed state before use?
There is no reason that the compressed air tank should have a lower temperature in the compressed state when the pressure was not changed for a couple hours. Metal, however, feels "cold" to touch even when at environment temperature due to the high thermal conductivity. Further, if air was let out shortly before, there could be a cooling effect due to the air expansion.
Added note: For a possible cooling effect due to recent gas expansion, which seems similar to the cooling of aerosol spray containers, I found this question with answers on SE: Why does the gas get cold when I spray it?
- 18,177
Observations over centuries have given us the ideal gas law .
where :
P is pressure, V is volume, and T is temperature
n = number of moles
R = universal gas constant = 8.3145 J/mol K
N = number of molecules
k = Boltzmann constant = 1.38066 x 10^-23 J/K = 8.617385 x 10-5 eV/K
k = R/NA
NA = Avogadro's number = 6.0221 x 10^23 /mol
This says that, for a given volume, when the pressure falls in a fixed volume, the temperature falls. That is exactly what is happening when compressed gas is let out from a closed bottle. It is extremely apparent if you make a mistake in changing a camping gas little bottle and the gas starts leaking.
Now at the molecular level, temperature is proportional to the average kinetic energy of the compressed molecules. When a bunch of them leaves as the valve is opened, due to the pressure the tail of the high kinetic energy distribution will be leaving, lowering the average kinetic energy of the rest in the bottle. This is temporary, because the thermodynamic equilibrium with the surroundings will bring again the bottle temperature to room temperature ( with less pressure in the bottle according to the ideal gas law).
- 236,935
If the cylinder has reached the ambient room temperature then the important parameter is the difference between the cylinder’s temperature and the temperature of your fingers.
Heat will flow from a hot body to the cold body and if the temperature of your fingers have a higher temperature than the temperature of the cylinder then heat will flow from your fingers to the cylinder.
This will raise the temperature of the cylinder in the locality of your fingers.
Because the thermal conductivity of the material (steel?) of which the cylinder is large the heat transferred to the cylinder from your fingers will quickly flow into the rest of the cylinder, this effect reducing the temperature of the cylinder in contact with the fingers and not raising the temperature of the rest of the cylinder by very much.
As the cylinder acts as a heat sink whose temperature does not rise very much because of its bulk and your fingers are not getting enough “body heat” to maintain a constant temperature the temperature of your fingers drops which gives you the sensation that the cylinder is cold.
If you touched the ground on which the cylinder was resting you would not feel that the ground was as cold as the cylinder even though the ground and the cylinder were initially at the same temperature.
This is because the thermal connectivity of the ground is so much less than that of the cylinder so the temperature of the ground around your fingers rises and this means that the rate of heat flow from your fingers would be reduced, thus your fingers would be cooled less - the ground does not feel as cold.
- 104,498
Here's a conjecture which you may verify by doing some simple experiments if you have available an empty cylinder and a cylinder filled with compressed gas:
Compressing air sufficiently leads to liquefaction of some of its components, in particular water vapor (see this). If no precautions are taken to the contrary, a cylinder of compressed air contains liquid in equilibrium with its vapour at ambient temperature (assuming sufficient time has been allowed for equilibration). Your hand being warmer than the ambient, touching the highly conducting cylinder wall leads to transfer of heat into the liquid inside and its absorption by phase change of liquid-water to water-vapor. Compressed air cylinders are required to be kept out of direct sunlight to avoid gas expansion by direct heating and perhaps also due to phase change (although no one seems to mention this explicitly). This is perhaps why compressed air cylinders feel cold even before use.
P.S. Of course an experiment must be done to verify that the cooling effect is not exclusively due to cylinder wall being metal as some of the answers have suggested.
- 6,642
