The integral is infra-red divergent. Power counting is about ultra-violet divergences. As you can check for yourself, the singular behaviour is in the lower limit:
\int_\epsilon^\infty \frac{1}{x^n}\mathrm dx=(1-n)^{-1}x^{1-n}\bigg|^\infty_\epsilon\sim\epsilon^{1-n}
which blows up if $n>1$.
The superficial degree of divergence tells you that the integral is superficially convergent as far as the $k\to\infty$ integration region is concerned. It tells nothing about possible singularities at finite values of $k$. In other words, the degree of divergence is all about the UV, but it knows nothing about the IR. In this example, the singularity is of the second type.
To regulate this integral you have to introduce a non-zero mass in the propagators, or use the dimensional regularisation trick
\int x^n\mathrm dx\equiv 0\quad \forall n
which is known as Veltman's formula. It can be argued that this formula is consistent as far as perturbation theory is concerned. Pragmatically speaking, this can be accomplished by introducing a non-zero mass and taking the massless limit carefully. In more formal terms, the consistency of the prescription can be proven by means of analytical continuation to complex $n$ (cf. 1.1666512).
For more details, see Massless integrals in dim-reg and Divergence of the tree level scattering amplitude in quantum field theory. The latter contains a list of useful references on IR divergences, their physical meaning and regularisation techniques.
