After solving the eigenvalue equation for the momentum operator, I get $u(x)=Ce^{ipx/\hbar}$, just like in Gasiorowicz's chapter 3. And then it says there:
"...and the eigenvalue $p$ real, so that the eigenfunction does not blow up at either $+\infty$ or $-\infty$....".
Doesn't the obtained solution always blow up at $+\infty$ and is 0 for $-\infty$? What happens if $p$ is imaginary?
Also, he says further on "this is the only constraint on $p$: we say that $\hat{p}$ has a continuous spectrum". This only happens for the free particle right? For a particle in a box, for example, the momentum is quantized, correct?
