Why is it that the classical path gives the dominant contribution in the quantum mechanical path integral? How do we understand this?
In the classical limit $\hbar\to 0$, this is just the WKB/stationary phase approximation.
Heuristically, near a stationary field configuration $\phi_0$ with $$\left. \frac{\delta S[\phi]}{\delta\phi}\right|_{\phi_0}~=~0\tag{1}$$ in field configuration space, the action $$S[\phi]~=~S[\phi_0]+{\cal O}\left((\phi-\phi_0)^2\right)\tag{2}$$ varies slowly, so the phase factors $\exp\left(\frac{i}{\hbar}S[\phi]\right)$ from neighboring field configurations sum up, and give a contribution; while away from a stationary field configuration $\phi_0$, the action varies rapidly, and the phases of neighboring field configurations are uncorrelated and cancel in average.
Perturbatively, near each stationary field configuration $\phi_0$, let us parametrize the field $$\phi^k~=~\phi^k_0+\sqrt{\hbar}\eta^k\tag{3}$$ in terms of a quantum fluctuation field $\eta^k$. Then the argument of the exponential reads$^1$ $$\begin{align}\frac{i}{\hbar}S[\phi]~=~&\frac{i}{\hbar}S[\phi_0] ~+~ \frac{i}{2}H_{k\ell}[\phi_0]~\eta^k\eta^{\ell} \cr &~+~ {\cal O}(\sqrt{\hbar}),\end{align}\tag{4} $$ where $$ H_{k\ell}[\phi]~:=~ \frac{\delta^2 S[\phi]}{\delta\phi^k\delta\phi^{\ell}}\tag{5}$$ is the Hessian. The path/functional integral $$\begin{align}Z~=~~&\int\!{\cal D}\frac{\phi}{\sqrt{\hbar}}~\exp\left(\frac{i}{\hbar}S[\phi]\right) \cr \stackrel{(3)+(4)}{=}&\sum_{\phi_0}\int\!{\cal D}\eta~\cr &\exp\left(\frac{i}{\hbar}S[\phi_0]+\frac{i}{2}H_{k\ell}[\phi_0]~\eta^k\eta^{\ell} + {\cal O}(\sqrt{\hbar})\right)\cr \stackrel{\text{WKB}}{\sim}~&\sum_{\phi_0}{\rm Det}\left(\frac{1}{i} H_{k\ell}[\phi_0]\right)^{-1/2}~\exp\left(\frac{i}{\hbar}S[\phi_0]\right)\cr &\quad\text{for}\quad\hbar~\to~0\end{align}\tag{6} $$ becomes formally a sum over instantons $\phi_0$, i.e. classical field configurations.
For a simple introduction into this topic with many pictures and almost no formulas, see e.g. this blog post by The Physics Mill.
$^1$Here we are using DeWitt condensed notation.
- 220,844
The contribution of paths deviating from the classical path are suppressed by interference.
- 27,443
