This question states that measuring the spin of an entangled particle causes the collapse of the wavefunction and thus the entanglement is broken.
Then this question states that we don't know what exactly is the cause for the collapse of wavefunctions.
However, what processes are known to collapse the wavefunction, and specifically break entanglement?
So measuring the spin collapses the wavefunction. What else does?
  • Chemical processes?
  • Presence in magnetic field without a screen (similar to Stern-Gerlach experiment)?
  • Irradiation of some form?
  • Heating?
EDIT
Given comments that the collapse of the wavefunction is still not understood, I'd like to emphasize experimental observations.
Also, given that the collapse of a wavefunction may or may not be an artificial construct, can we focus on what processes have been observed to destroy entanglement?
(From what I understand of current theory, entanglement is only broken by the resolution/collapse of the wavefunction, thus asking "what has been observed to collapse the wavefunction" and "what has been observed to break entanglement" should be questions with the same answers.)
Roman
  • 363
Since you already talk about Stern-Gerlach, I suspect that the focus of your question is more about at which point in existing experimental techniques the collapse occurs, and not about learning existing techniques. In Stern-Gerlach that would be the deflection, not the screen, because this is where the spin value gets to be determined. If I got the question right, then the general answer is "at the point in the experiment where the studied property gets a specific value and superposition ends".
Also: Measuring is interacting with the system under study. There is nothing special putting measurement apart from any other physical process. This means that any interaction of the original system with anything else in the universe will break the wavefunction, preparing a new state.
I think the most concise (and entertaining) answer was the first comment (source) in the first of your links:
Basically, for observations to happen, there has to be an interaction between particles, or as the post put it less/more(?) eloquently, whenever a physicist says "observe", mentally replace it with "hit with sh*t.
Roman
  • 363
Helen
  • 904
The wavefunction doesn't collapse. Rather, when you do a measurement, each of the possible outcomes happen, but they are dynamically isolated from one another by decoherence and act approximately like non-interacting versions of the same object - this is commonly called the many worlds interpretation of quantum mechanics and treated as some controversial optional extra, but it is just a consequence of taking the equations of motion of quantum mechanics seriously as a description of how the world works.
Entanglement itself involves system 1 having information about system 2 that can't be accessed except by direct interaction or comparing results of measurements on them (locally inaccessible information):
https://arxiv.org/abs/quant-ph/9906007
https://arxiv.org/abs/1109.6223
If system 2 interacts with some other system, system 3, then the locally inaccessible information is now in the joint system of system 2 and system 3. As such, system 2 alone no longer contains the information required to do entanglement type stuff. And if system 3 is the environment, then in practice it is impossible to get that locally inaccessible information back. So systems 1 and 2 are effectively disentangled.
alanf
  • 11,359
  • 16
  • 33
Imo the term "collapse of the wavefunction" is a misleading term for "interaction" or measurement..
The wavefunction is not measurable,it is a complex-number mathematical function necessary for calculating quantum mechanical probabilities of an interaction happening. It is not an observable balloon that can collapse. Only the complex conjugate square of a wavefunction is observable
Take a simpler mathematical solution , the parabola of a projectile: Is the parabola observable? Only the projectile's motion is observable. If suddenly the projectile changes direction, we will not say that the parabola was broken. We will look for the obstruction in the path of the projectile, i.e an interaction that will change the model function.
The wave function is a solution of a quantum mechanical differential equation with the boundary conditions of the problem. Any interaction changes the boundary conditions, and measurements are interactions.The measurement will give one point in the probability density distribution which can be measured by repeating the process many times.
This single electron double slit accumulation can give an intuition of how a probability density is connected with individual measurements:
dblsslit
Electron buildup over time
Each electron fired at the two slits has a probability on ending as a point in the screen. Once it hits the screen its wavefunction is no longer controlled by the boundary conditions "electron impinging on two slits with given dimensions". It has been absorbed in the screen raising dots from a large number of ionizing interactions with the molecules of the screen.
Does it have a meaning to ask whether the "wave function collapsed"? A new wavefunction is needed the instant the electron impinges on the first atom of the screen.
The wave function leaves its imprint in the probability distribution shown in the later slides, showing the wave nature of the electron, which is the complex conjugate squared of the wavefunction. For a single electron only a point can be seen.
So all quantum mechanical solutions of specific boundary value problems give wave functions which , once the boundary conditions change, by interactions, the old wave function is not longer valid and a new one has to be calculated with the new boundary conditions.
anna v
  • 236,935
