I'm trying to build a ballistics simulation where I shoot a cannonball. I want to allow for drag and am trying to work out the math to do so.
I can work the drag out using $F = C_d\times S\times V^2\times A/2$.
What I need to know is how to find the $x$ and $y$ parts of that. I use $V\cos(A)$ and $V\sin(A)$ to work out the $x$ and $y$ velocities. Can I just use this to find the $x$ and $y$ drag too?
1ftw1
  • 101
With the drag force $$ {\bf{F}}_d = - \alpha \left|{\dot{\bf r}}\right|^2 \frac{{\dot{\bf r}}}{\left|{\dot{\bf r}}\right|} = - \alpha \left|{\dot{\bf r}}\right| {\dot{\bf r}}, $$ where $\alpha = \rho C_d A / 2$, the equation of motion for the cannonball is $$ m {\ddot{\bf r}} = - m g \ {\hat{\bf y}} + {\bf{F}}_d = - m g \ {\hat{\bf y}} - \alpha \left|{\dot{\bf r}}\right| {\dot{\bf r}}, $$ or $$ \begin{align} {\ddot{x}} &= f_x\left({\dot x}, {\dot y}\right) = - \beta {\dot{x}} \sqrt{{\dot x}^2+{\dot y}^2} \\ {\ddot{y}} &= f_y\left({\dot x}, {\dot y}\right) = - g - \beta {\dot{y}} \sqrt{{\dot x}^2+{\dot y}^2} \end{align} $$ where $\beta = \alpha / m = \rho C_d A / 2 m$.
Given initial conditions $x\left(0\right)$, $y\left(0\right)$, ${\dot x}\left(0\right)$, and ${\dot{y}}\left(0\right)$, you can then numerically integrate the system of equations ${\ddot{x}} = f_x\left({\dot x}, {\dot y}\right) $, ${\ddot{y}} = f_y\left({\dot x}, {\dot y}\right)$.
Eric Angle
  • 3,086
I am assuming you are plotting the path by incrementation. At any given moment, you have the force (in newtons) due to gravity ($m \cdot g$). Calculate the drag force (which is opposite to the direction of motion) and add or subtract the vertical component of the drag force (depending wether the ball is rising or falling) to the gravity force. Now you have the horizontal and vertical forces acting on the cannonball, install an incremental value for time for your impulse calcs, calculate the velocity change in both $x$ and $y$ directions and distance covered in the $x$ and $y$ directions using newtons classic equations. So at the end of each time increment, you have a new $x$ and $y$ for velocity and position.
Sebastiano
  • 2,681
