I am given an initial x and y position and initial velocity and I was asked to graph the trajectory in 1 second intervals.
This is what I have so far:
If $x_0 = 1, v_{0x} = 70, y_0 = 0, v_{0y} = 80, a_x = 0, a_y = -9.8$, and time will be 0,1,2,3... and so on.
Using these equations on every second you can find the plot will be a bell shaped with the highest point being ~ 325 m at about 600 seconds:
$$ x = x0 + (v_{0x})t + 1/2((a_x)t^2) $$ $$ y = y0 + (v_{0y})t + 1/2((a_y)t^2) $$
Usually in physics, we are taught in perfect condition with no air resistance. But what if there was air resistance? How would it affect this problem? How can i add it to my calculations and see what the difference is?
user2856118
  • 213
With drag force $- \alpha \left|{\dot{\bf r}}\right| {\dot{\bf r}}$ and gravitational force $-mg {\bf {\hat{y}}}$, the equations of motion are (see my answer to this question) $$ \begin{align} {\ddot{x}} &= - \beta {\dot{x}} \sqrt{{\dot x}^2+{\dot y}^2} \\ {\ddot{y}} &= - g - \beta {\dot{y}} \sqrt{{\dot x}^2+{\dot y}^2} \end{align} $$ where $\beta = \alpha / m$, $\alpha = \rho C_d A / 2$, $\rho$ is the air density, $C_d$ is the drag coefficient, and $A$ is the cross-sectional area of the projectile.
I've never seen the above equations solved analytically. Here's some Python code that plots the solution with and without air resistance. To run, copy into a text file myFile.py and run
python myFile.py
from the command line.
from pylab import *
import math
Physical constants
g = 9.8 m = 1.0 rho = 1.0 Cd = 1.0 A = math.pi * pow(0.01,2.0) alpha = rho * Cd * A / 2.0 beta = alpha / m
Initial conditions
X0 = 1.0 Y0 = 0.0 Vx0 = 70.0 Vy0 = 80.0
Time steps
steps = 1000 t_HIT = 2.0*Vy0/g dt = t_HIT / steps
No drag
X_ND = list() Y_ND = list()
for i in xrange(steps+1): X_ND.append(X0 + Vx0 * dt * i) Y_ND.append(Y0 + Vy0 * dt * i - 0.5 * g * pow(dt * i,2.0))
With drag
X_WD = list() Y_WD = list() Vx_WD = list() Vy_WD = list()
With drag
X_WD.append(X0) Y_WD.append(Y0) Vx_WD.append(Vx0) Vy_WD.append(Vy0)
stop = 0 for i in range(1,steps+1): if stop != 1: speed = pow(pow(Vx_WD[i-1],2.0)+pow(Vy_WD[i-1],2.0),0.5)
# First calculate velocity
Vx_WD.append(Vx_WD[i-1] * (1.0 - beta * speed * dt))
Vy_WD.append(Vy_WD[i-1] + ( - g - beta * Vy_WD[i-1] * speed) * dt)
# Now calculate position
X_WD.append(X_WD[i-1] + Vx_WD[i-1] * dt)
Y_WD.append(Y_WD[i-1] + Vy_WD[i-1] * dt)
# Stop if hits ground
if Y_WD[i] <= 0.0:
  stop = 1
Plot results
plot(X_ND, Y_ND) plot(X_WD, Y_WD) show()
Destaq
  • 105
Eric Angle
  • 3,086
