Consider the following standard case of an entanglement experiment:
  1. We prepared two electrons A and B with states
$$\lvert A\rangle=a_1\lvert \uparrow\rangle+a_2\lvert \downarrow\rangle$$ $$\lvert B\rangle=b_1\lvert \uparrow\rangle+b_2\lvert \downarrow\rangle$$ that are not entangled. If we measure any one of them, the spin obtained will be $\uparrow$ or $\downarrow$ with probability determined by the coefficients $a_i$ an $b_j$ for $i,j=1,2$
We can easily construct the product state by
  1. We then brought them close together, and then applied a suitable magnetic field with hamitonian $\hat{H}$. This rotates the state so that it is no longer a product state, thus entangling the two electrons.
$$e^{i\hat{H}t}\lvert AB\rangle=\lvert A'B'\rangle$$
  1. We then isolate them, and now perform a measurement on $\lvert A'B'\rangle$ on each of the electrons, return to compare results, in order to determine the observable $\sigma_{nAB}=(\vec{\sigma}\cdot \hat{n}_A)\otimes (\vec{\sigma}\cdot \hat{n}_B)$, where $\hat{n}_A\cdot \hat{n}_B=\cos\theta$ and $\theta$ is the angle between the two directions of the unit vectors in space. This will give one of the many outcomes on the pairs of spins as predicted by $\langle \sigma_{nAB}\rangle$.
  2. By repeating steps 1-3 many times, we noticed the correlations obey the usual correlation dependence on $\cos\theta$ found in Bell's Theorem.
Now compare the above with the following qualitative "watered down" analogy
  1. We prepared two marbles A and B, both colorless. Each carry an instruction of probability which reads as:
    When touched, turn into (R)ed $r_A$ amount of the time or (Y)ellow $y_A$ amount of the time
similarly for B. Should we decide to touch either of them, they will change color, and we found there is no correlation between the colors R and Y.
  1. We brought the marbles close together, leave that for some known amount of time t. The two marbles are still colorless.
  2. We then isolate them. We then touch one of the marbles (A or B). Suppose for this trial we got A turned R. We then go back to where B is kept, and we found it turned Y.
  3. Repeat Steps 1-3 many times and we found that R and Y are correlated in a way that agrees with the resulting probability of what happens when objects with some given instruction of probability (inferred during the preparation of the marbles) is being place close together for time t.
Comparing between these two descriptions, it seems to suggest the correlated outcomes that is predicated by the $\cos \theta$ relationship of the violation of Bell's Theorem was established at the moment when the two electron became entangled hence their state cannot be factorised into a product state anymore, and hence their probabilities also become correlated.
The measurement then pick out one of the outcomes of this correlated probability distribution (which is determined by the wavefunction) thus there is no need of the notion that measurement of one electron instantly changes the other.
We also knew that the time evolution of the wavefunction hence the probability of some observable of the state is deterministic and obeys a Schrödinger equation.
Therefore this suggests the wavefunction of the electron is an intrinsic property similar to charges that can be transformed and shared between other electrons, and entanglement introduce correlations in this intrinsic property.
Now since the wavefunction is not an observable, hence unmeasurable, and even its probability can only be inferred from an ensemble of states and not just by measurement of one state. Yet it pretty much controls all the possible outcomes we can obtain from the experiment, with deterministic time evolution, and it effectively span across spacelike distances between the subsystems, it seems to qualify as a non-local hidden variable.
Yet nobody refer to the wavefunction as a hidden variable.
Why is the wavefunction not considered a (non-local) hidden variable?
Secret
  • 935
