1) Both: it is apparently a heat equation in imaginary time and it is a wave equation because its solutions are waves.
2) Nonstationary Schrodinger equation (let us assume free particle)
i\hbar\frac{\partial\psi}{\partial t}=-\frac{\hbar^2\nabla^2}{2m}\psi
is essentially complex: it can never be satisfied by a real function, only by a complex one.
Nevertheless, its solutions are waves because the complex $\psi$ means it is actually a system of two real equations of the first order in time. Assuming $\psi=u+iv$ we have:
\hbar\frac{\partial u}{\partial t}=-\frac{\hbar^2\nabla^2}{2m}v,\qquad
\hbar\frac{\partial v}{\partial t}=\frac{\hbar^2\nabla^2}{2m}u.
Eliminating, say, $v$, we get:
\hbar^2\frac{\partial^2 u}{\partial t^2}=-\frac{\hbar^4\nabla^4}{4m^2}u.
In two dimensions, this equation has the same form as a wave equation for bending (flexural) waves on a thin rigid plate. It is also of the 2-nd order in time and 4-th order in coordinates. The analogy extends also to wave dispersions: the bending waves have a quadratic dispersion $\omega\sim q^2$ similarly to free particle obeying Schrodinger equation $E=p^2/2m$.
3) This analogy is widely used in the diffusion Monte-Carlo method, where the Schrodinger equation is solved in imaginary time. In this case, its solution is decaying instead of being oscillatory and, if we normalize it properly, it will converge to the ground state wave function:
https://en.wikipedia.org/wiki/Diffusion_Monte_Carlo
http://www.tcm.phy.cam.ac.uk/~ajw29/thesis/node27.html
What is diffusing here? Taking imaginary time $\tau=it$, we have the following imaginary time Schrodinger equation for a particle in a potential $V$:
\hbar\frac{\partial\psi}{\partial t}=\frac{\hbar^2\nabla^2}{2m}-V\psi.
The first term in right hand side is usual diffusion. The second is something like heat production or burning, and its "minus" sign means this heat production is more intense in the minima of $V$.
Thus, the picture of diffusion in imaginary time is the following: the first term ("diffusion") tries to delocalize $\psi$, while the second term tries to lure $\psi$ to the minima of the potential $V$. Their interplay is the same as that between kinetic and potential energies in quantum mechanics, and its result is a ground state wave function - exactly what is used in diffusion Monte-Carlo calculations.
