Photoemission in the usual experiment is a two step process. First the incident photon creates a photoelectron in the bulk of the metal:
The quantum efficiency for this is almost $100$% i.e. almost every photon that hits the metal creates a primary photoelectron. However this photoelectron is heading in the same direction as the original photon i.e. down into the bulk of the metal. For the electron to escape from the surface it has to rattle around bouncing off other electrons and nuclei in the metal:
However this process is very inefficient. Only about $1$ in $100,000$ of the primary photoelectrons manages to bounce back towards the surface and escape. So the overall yield is around one photoelectron emitted from the surface for every hundred thousand photons.
The electron will normally lose some energy $\Delta E$ while it's bouncing around, then it loses an energy equal to the work function when it escapes from the surface, so the final electron energy will be:
$$ E = h\nu - \Delta E - W $$
The work function is a constant, but the energy lost in scattering, $\Delta E$, is very variable and can range from almost zero to so large that the electron never escapes.
I won't go through your questions 1 to 4 in detail because this is obviously a homework question. However from the explanation above you should be able to work out what the answers are.
