I'm a little confused about the idea of spin. It's been non-technically described to me as "like magnetic dipole moment", except only two possible "directions". But I feel like that's a bad analogy, because direction is relative and 3 dimensional.
I understand that under the Ising model, spin has +1 or -1 values, and in the case of a pi meson, 0 (is that because of an alignment of quark-antiquark spins?)
So, then, spin of a particle would be the sum of spin of its quarks, which explains half-spin?
And in light of a recent observation of photons behaving as both a wave and a particle in a single experiment, could one say that spin direction is the direction of the valley and the peak of a wave, and the angular momentum is simply the two dimensional gradient of the wave itself? In other words, is the angular momentum of spin measured as the "up" and "down" "motion" of the compression of energy fields where the spin direction is the alignment of the "up" and "down" peaks/valleys, relative to whatever dimension on which the wave propagates?
I guess what I'm getting at is I'm trying to understand whether particles are just wave interference patterns (actual, not probability) of compressed and decompressed energy across the extra dimensions which we do not call home.
Dexter
  • 139
Within the context of first quantization (the Schrodinger equation), spin itself is not characterized by the spatial or momentum space wave function (the function that defines a complex quantity over all space). It is instead treated with a separate Hilbert space that quantifies the spin states 'tacked on' to this wavefunction by an outer product. It is a matter of semantics whether you consider 'wavefunction' to refer to the complex field alone, or the composite field/spin hilbert spaces.
More advanced field equations incorporate spin more naturally. The Dirac equation, for example, no longer describes the evolution of a complex scalar field, but the evolution of a four-vector, that naturally describes spin states. For this system, spin $\textit{is}$ characterized in the wavefunction itself.
anon01
  • 1,631
