Since the energy spectrum does not depend on the absolute position $\vec{r}=\vec{a}$ of the delta potential, we may assume that $\vec{a}=\vec{0}$. Therefore, in its current formulation (v1), OP is effectively saying that
The attractive 1D delta potential $V(x) = -A\delta(x)$, $A>0$, has exactly one bound state. The same is true for the 3D delta potential $V(\vec{r}) = -A\delta^3(\vec{r})$.
No, the bare 3D delta potential does not constitute a well-posed mathematical problem without some kind of regularization/renormalization, see e.g. Ref. 1 and Ref. 2.
Theorem. The attractive delta potential has infinitely many bound states, and the spectrum is not bounded from below, if the spatial dimension $\color{Red}{n\geq 2}$.
Simpler proof for $\color{Red}{n>2}$: The unboundedness from below is rigorously proven via the variational method. Consider a normalized Gaussian test/trial wavefunction
$$\psi(r)~=~Ne^{-\frac{r^2}{2L^2}}, \qquad \int d^nr~|\psi(r)|^2 ~=~\langle\psi|\psi \rangle~=~1,$$
where $N,L>0$ are two constants. For dimensional reasons, the constant $L$ must have dimension of length, and $1/N^2$ must have dimension of $(\text{length})^n$. It follows that
The normalization constant $N$ must scale as
$$N ~\propto~ L^{-\frac{n}{2}}.$$
The expectation value $\langle\psi| K|\psi \rangle$ of the kinetic energy operator $K=-\frac{\hbar^2}{2m}\Delta$ must scale as
$$0~\leq~\langle\psi| K|\psi \rangle ~\propto~ L^{-\color{Red}{2}},$$
essentially because the Laplacian $\Delta=\vec{\nabla}^2$ contains two position derivatives.
The expectation value $\langle\psi| V|\psi \rangle$ of the potential energy $V=-A\delta^3(\vec{r})$ must scale as
$$0~\geq~\langle\psi|V|\psi \rangle~=~-AN^2~\propto~ -L^{-\color{Red}{n}}.$$
Now assume that $\color{Red}{n>2}.$ Thus by choosing $L\to 0^{+}$ smaller and smaller, the negative potential energy $\langle\psi| V|\psi \rangle\leq 0$ beats the positive kinetic energy $\langle\psi| K|\psi \rangle\geq 0$, so that the average energy $\langle\psi| H|\psi \rangle$ becomes more and more negative,
$$ \langle\psi| H|\psi \rangle ~=~\langle\psi| K|\psi \rangle + \langle\psi| V|\psi \rangle ~\to~ -\infty \qquad \text{for}\qquad L\to 0^{+}. $$
Hence, the spectrum is unbounded from below. (This proof also shows the $\color{Red}{n=2}$ case for a sufficiently large $A$.) $\Box$
Proof for $\color{Red}{n=2}$: If there exists a normalized energy eigenfunction $\vec{r}\mapsto \psi_1(\vec{r})$ to the TISE $H\psi_1=E_1\psi_1$ with negative energy $E_1<0$, then it is easy to see by a scaling argument that there exists a whole 1-parameter family
$$\begin{align} \psi_{\lambda}(\vec{r})~=~&\lambda\psi_1(\lambda\vec{r}),\qquad H\psi_{\lambda}~=~E_{\lambda}\psi_{\lambda}, \cr
E_{\lambda}~=~&\lambda^2E_1~<~0, \qquad \lambda~>~0, \end{align}$$
of normalized energy eigenfunctions. Together with theorem 1 from my Phys.SE answer here, we conclude that the spectrum is unbounded from below. $\Box$
References:
S. Geltman, Bound States in Delta Function Potentials, Journal of Atomic, Molecular, and Optical Physics, Volume 2011, Article ID 573179.
R.J. Henderson and S.G. Rajeev, Renormalized Path Integral in Quantum Mechanics, arXiv:hep-th/9609109.
