I think I have understood properly the principle of LIGO, however the sensitivity is around $10^{-18}~\rm m$ of accuracy of distortion. That looks pretty small... just starting with simpler phenomena, for example, thermal expansion. In order to avoid thermal expansion, the temperature needs to be control within a variation of $10^{-10}~\rm K$ or $10^{-11}~\rm K$ along the tubes.
I guess that the tubes do not need to be exactly $4~\rm{km}$ equal as the lasers can be synchronized although the distance is not exactly 4km within the range of $\left[10^{-18}~\rm m\right]$
How is the thermal noise avoided currently in LIGO, related to suspension and not complete vacuum?
It is already demonstrated that the frequency cut-off is low, but, how is that achieved? Which materials and isolation supported it?
The LIGO experiment doesn't measure the length of the tubes, it measures the changes in the length of the tubes.
It also has a lower frequency cut-off of 10Hz, so any perturbation that is slower than 10Hz won't affect the measurements. In particular temperatures changes will happen on a timescale of hours so if they change the length of the tube that doesn't matter. When LIGO measures the $10^{-18}$ m change in the tube length it doesn't matter if that length is a bit longer at midday than at midnight.
The accepted answer to the question suggested as a duplicate, How does LIGO remove the effects of environmental noise?, includes a graph of possible perturbations as a function of frequency, and you'll note that the frequency scale doesn't go below 1Hz because frequencies below that don't matter.
John Rennie
  • 367,598
