The upthrust on the balloon is equal to the weight of air displaced, so we get:
$$ F = V_b \rho g \tag{1} $$
where $V_b$ is the volume of the balloon and $\rho$ is the density of the air. Assuming air is approximately an ideal gas it obeys the equation of state:
$$ PV = nRT $$
so the molar density is:
$$ \rho_M = \frac{n}{V} = \frac{P}{RT} $$
where $n$ is the number of moles of air. The density in kg/m$^3$ is given by multiplying the molar density by the (average) molar mass of the air $M_{\text{air}}$, and substituting this in equation (1) we get:
$$ F = V_b M_{\text{air}} g \frac{P}{RT} \tag{2} $$
Now let's consider what happens to the volume of the balloon. We'll take the two extreme cases where the rubber skin is infinitely rigid and where it's infinitely compliant.
First consider the case where the rubber skin is infinitely compliant i.e. it doesn't exert any force on the helium inside it. In that case the volume of the helium is (approximately) given by the ideal gas equation:
$$ V_b = \frac{n_{\text{He}}RT}{P} $$
where $n_{\text{He}}$ is the number of moles of helium. Substituting this into equation (2) we get:
$$ F = n_{\text{He}} M_{\text{air}} g $$
which is constant. So in this case we find that the bouyancy is unaffected as the pressure and temperature change.
Now consider what happens if the rubber skin is infinitely rigid, in which case the volume $V_b$ is constant. We end up with:
$$ F \propto \frac{P}{T} $$
In this case the bouyancy is affected by the pressure and temperature. Assuming the pressure is approximately constant the bouyancy is inversely proportional to temperature so the balloon will rise when it gets cold and fall when it gets hot, which matches your observation.
I've taken the two extreme cases because I don't know the equation for the force produced by the rubber skin of the balloon. However it is presumably somewhere in between the two extremes I've discussed, so we expect the behaviour of the balloon to fall between those two extremes. That means we expect the bouyancy will increase as the temperature decreases and vice versa.
