Currently I'm doing a physics related coursework on guitar strings and wave. I would like to ask how I can model the sound wave of a guitar with an equation. I asked some of my teachers and they told me that I should use Fourier analysis, but after reading it from Wolfram Alpha and doing a few example questions, I still don't know how to model the sound wave of a guitar. Can someone give me some advice or tell me if I'm doing anything wrong?
Sean
  • 3,033
So the shape of the string (of length $\ell$) is defined with a general series equation that depends on constants $A_1,A_2,\ldots$ and $B_1,B_2,\ldots$.
$$ y(x,t) = \sum_{i=1}^{\infty} \sin \left(\frac{i\pi x}{\ell} \right) \left( A_i \sin \left( \frac{i \pi c t}{\ell} \right)+ B_i \cos \left( \frac{i \pi c t}{\ell} \right) \right) $$
The wave speed $c$ is defined from the tension $T$ and the mass per length with $c^2 = \dfrac{T}{{m}/{\ell}}$
If you can fit the initial shape of the plucked string into the equation above, and match the coefficients then you can know the relative amplitude $\sqrt{A_i^2+B_i^2}$ for each frequency $f_i =i \frac{c}{2 \ell} $ for $i=1\ldots\infty$
reference: http://hyperphysics.phy-astr.gsu.edu/hbase/waves/string.html
To match the shape of a plucked string with a finger a distance $x_p$ from the end of the string use $$ y(x,0) = \begin{cases} Y\frac{x}{x_p} & 0\leq x \leq x_p\\ Y\left(1-\frac{x-x_p}{\ell-x_p}\right) & x_p > x \leq \ell \end{cases} $$
and $\dot{y}(x,0)=0$ since the string is at rest initially. This yields the following coefficients (using Fourier analysis) with $i=1\ldots n$ coefficients. How to choose the number of terms $n$ is up to you.
$$\begin{align} A_i &= 0 \\ B_i &= Y \frac{2 \ell^2 \sin \left( \frac{i \pi x_p}{\ell} \right)}{\pi^2 i^2 x_p (\ell-x_p)} \end{align} $$
Finally, to go from the string shape to the corresponding wave amplitude of sound is beyond my abilities and maybe someone else can chime in.
John Alexiou
  • 40,139
To some approximation -- probably a pretty bad one -- a guitar string is described by simple wave equation for small enough oscillations. If $y(x,t)$ is the displacement of a portion of the guitar string $x$ meters from the fretboard, at time $t$, then the equation governing the motion is: $$c^2\frac{\partial ^2 y}{\partial x^2}= \frac{\partial^2 y}{\partial t^2}$$ This short equation gives rise to all of the animations in the wikipedia page I linked, and it is solved by any solution of the form $$A\sin(\frac{\omega}{c} (x-c t)+\alpha)$$, where $\alpha$ is a constant angle, $A$ is in meters and is the amplitude of the wave, and $\omega$ is the [angular] frequency of the wave.
This equation also has solutions of the form $f(x-ct)$, for ANY function $f$. This means you can have a waveform of any shape travelling down the string.
In addition to that, ja72's method also solve the wave equation.
And finally, you can solve it numerically. I wrote this little seventeen line javascript program for situations like this! Watch out though, the code may still be too complicated. In the limit of an infinite number of circles, this simulation solves the simple wave equation. The only rule in the simulation is that neighboring circles influence each other (in the vertical direction only) according to Hooke's law.
